Factory LSD Question
Old Oct 30, 2003 | 08:54 PM
9200RPM's Avatar
Default Factory LSD Question
Can the factory LSD be taken from a Hydro tranny and be put in a Cable tranny...If so is it just a direct replacement...I know factorys aren't that great but I have one for free...so I want to use it to its full advantage..Thanks
Cameron
Old Oct 30, 2003 | 09:21 PM
gamakichi77's Avatar
Default Re: Factory LSD Question (TurboB16aEG)
it can't be used.......LSD for Cable type and Hydro is different. it can't be interchangeable. But, one type of cable tranny from Integra can use hydro LSD. i can't remember the tranny code. There's no more sticker on it. but i take it from Integra front cuts.
Right now i'm using cable tranny and using CTR LSD and all gear ratios with 4.785 final gear. So responsive.
Old Oct 30, 2003 | 09:25 PM
9200RPM's Avatar
Default Re: Factory LSD Question (acidburns_di)
Did you swap the internals out to get that to work..I dont like my cable tranny...but that because I have the conversion kit...My 3rd gear is gone..and when I change the syncros I want to put some type of LSD in it...
Old Oct 30, 2003 | 09:49 PM
i'm just take out all of gear ratios from my cable tranny, and put all the gear ratios from CTR tranny. its interchangeable. But for Y1 it can't. i can't remember my code tranny. sticker gone already. Just this type of cable tranny only can use Hydro gear ratios and LSD. others cable tranny, not interchangeable.
where is your 3rd gear. u should have all the ratios in.
Old Oct 30, 2003 | 09:50 PM
mmuller's Avatar
Mad Scientist
you can, but its complicated:
http://courtneyeg9.streetracin....html
Old Oct 30, 2003 | 10:55 PM
irev210's Avatar
Default Re: Factory LSD Question (mmuller)
YS1 92-93 you can
The gear set is the same gear set that is in hydro trans
the casing is different so you have to shave a lil off the casing for the LSD diff to fit.
And btw, oem honda lsd difs are really nice
Old Oct 31, 2003 | 03:36 AM
PHiZ's Avatar
Default Re: Factory LSD Question (irev210)
I thought I heard that that there was a change in spline sizes that happened to co-incide with the jump from cable to hydro...
-PHiZ
Old Oct 31, 2003 | 07:54 AM
owen_the_soyboy's Avatar
Default Re: Factory LSD Question (PHiZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PHiZ &raquo;</TD></TR><TR><TD CLASS="quote">I thought I heard that that there was a change in spline sizes that happened to co-incide with the jump from cable to hydro...
-PHiZ</TD></TR></TABLE> true, but the USA 92-93 GSR is the only cable tranny with the BIG spline, in fact you can swap internals from the 92-93 GSR tranny with other Hydro trannies
Old Nov 1, 2003 | 02:08 PM
9200RPM's Avatar
Default Re: Factory LSD Question (owen_the_soyboy)
My syncros have gone bad to my 3rd gear...so I have a turbo car with no 3rd gear...kinda pisses me off..
mycrx7
23
Jul 13, 2010 10:41 PM
Lsos
Feb 23, 2006 09:22 AM
darkdemon215
Jun 8, 2004 04:57 PM
