F22A6 to H23A engine swap Non-vtec
The swap was done on a 93 honda accord se coupe. The intake from the F22A was mounted onto H23A motor. Everything matched perfectly, EXCEPT the distributor. The JDM H23A motor has an internal coil on the distributor. Whereas the F22A had an external coil. How do adapt to the connector from the wireharness that went to the external coil to power the internal coil. Also, will my F22A6 ECU work with my JDM H23A? The job is almost complete, and engine will not crank over. I would appreciate any help whatsoever to get this swap complete. thanks
99EX_GLB
Oct 19, 2006 08:57 PM
Broken Devil
Oct 18, 2005 11:13 AM
