F20b Temperature sensor question. Which one to use as a replacement?
Old May 21, 2018 | 05:28 PM
Fswap's Avatar
Default F20b Temperature sensor question. Which one to use as a replacement?
Noob here
Im new to this swap and learning as I go so bare with me on the stupid questions. My temperature sensor just went bad I tried a H series but it was way to small any advise?
Old Feb 18, 2024 | 07:04 AM
Fly.Trap47's Avatar
Default Re: F20b Temperature sensor question. Which one to use as a replacement?
Originally Posted by Fswap
Noob here
did you ever figure it out? I believe the code 6 is for the sensor below the distributor. I just got a valve job done on my f20b head put it all back together and at first I hadn’t plugged them in right but now I have it all hooked up correctly it still throws code 6 and has a super rough cold start then revs up to 2100 rpm’s for a few seconds then dies
ezekel
Audio / Security / Video
Nov 9, 2005 04:04 AM
