extra fitted rear mount = more traction?
Old Feb 9, 2004 | 11:38 PM
F120man's Avatar
New User
Default extra fitted rear mount = more traction?
hey, i was thinkin bout finding ways to get more traction one day. so i got high that day to see if my mind could come to some ideas. i thought about how traction bars worked, and how they stiffened up the chassis for more grip. i then realized, if i the rear mount could squeeze into the chassis by slightly tilting the side mounts. to cause the motor to be more secured to the rear chassis, thus less wheel hop. do you guys think this theory can work?
Old Feb 10, 2004 | 12:18 AM
kommon_sense's Avatar
Default Re: extra fitted rear mount = more traction? (F120man)
I think that you should stop getting high. Second, sounds like you are going to wear out the rubber in the mounts faster. Also, I thought that traction bars worked by limiting the deflection under hard braking/accelerating on the front lcas.
Old Feb 10, 2004 | 08:30 AM
mmuller's Avatar
Mad Scientist
you can just get poly mount inserts
Old Feb 10, 2004 | 11:42 AM
F120man's Avatar
New User
Default Re: extra fitted rear mount = more traction? (mmuller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kommon_sense &raquo;</TD></TR><TR><TD CLASS="quote">I think that you should stop getting high. Second, sounds like you are going to wear out the rubber in the mounts faster. Also, I thought that traction bars worked by limiting the deflection under hard braking/accelerating on the front lcas.</TD></TR></TABLE>
oh yeah, i gotta stop gettin high. thanks tho
preludeNApower
Jan 12, 2012 08:35 AM
Boner_Ben
May 29, 2007 03:21 PM
Baron55
May 21, 2007 06:57 PM
smackdown
Feb 17, 2007 11:24 PM
Fly1865
Jun 7, 2004 05:43 AM
