Exhaust system replacement process...which way?
Old Jul 16, 2004 | 06:22 AM
Yodzilla's Avatar
Default Exhaust system replacement process...which way?
Here's a question some friends of mine have been kicking around. When overhauling your exhaust for any car (my car is a 98 Accord 4cyl), is it better to start with a cat-back system, replace the catalytic converter, then swap headers; or do it the other way around, headers to catalytic converter to cat-back? This is assuming that your system has been well planned out and your not just slapping "performance" parts on that might not play well together.
Old Jul 16, 2004 | 06:32 AM
civicminded92's Avatar
Default Re: Exhaust system replacement process...which way? (Yodzilla)
If you are speaking in terms of performance gain, starting with the cat-back will probably be best. Here's why - if you start at the header you still have a restrictive exhaust behind it.
This is a big generalization without knowing which of the stock peices is the most restrictive. If you knew that, that's where you'd want to start.
My $.02
12TSXSE
Acura TSX
Dec 24, 2013 02:32 PM
bgoetz
Nov 20, 2003 08:11 AM
Toptul_Honda
10
Nov 9, 2002 01:41 PM
