Evap Canister
Old Aug 15, 2002 | 02:53 PM
Chuji's Avatar
Default Evap Canister
There is a hole located on the back of the block to the bottom right of the oil filter. I noticed it runs down into the oil pan. On my 96 ls block this hole is capped by a peice of metal from the factory, on my 90 block the hole is open. Someone told me I need to buy some sort of canister to hook up, or can I just clog it somehow. This is an ls/vtec motor and I was just wondering what exactly i need to do.
Old Aug 16, 2002 | 12:21 AM
kinesistech's Avatar
Default Re: Evap Canister (Chuji)
On earlier model b18's they use an air/oil seperator. Its for the pcv system, notice the pcv is connected to it. On later b 18's there is a pcv on the valve cover. The whole system is in the block. When building an ls/vtec IMO its better to have the older style with a factory seperator. You will have a functioning pcv system.
Old Aug 16, 2002 | 10:09 AM
Chuji's Avatar
Default Re: Evap Canister (kinesistech)
Do you know where I could locate one of these? The pcv system didnt come with my block so ive gotta find one fast. Do domestics use air/oil seperators? Or is there any universal kit i could buy? I was planning on just cutting a perfect circle of metal and jb welding it over that hole? bad idea?
Old Aug 16, 2002 | 12:49 PM
Chuji's Avatar
anyone?
Old Aug 16, 2002 | 01:26 PM
ViZ's Avatar
ViZ
once you find a way to cover it you can use an external catch can.. i may be wrong let me know
Old Aug 16, 2002 | 01:53 PM
Chuji's Avatar
Default Re: Evap Canister (ViZ)
Is the part I need called a vapor canister?
egcoupe007
Jun 30, 2011 08:07 AM
The DX Rex
Jul 25, 2010 12:36 PM
libral00
Mar 30, 2008 09:57 AM
Chuji
May 17, 2004 03:09 PM
Huee
Apr 28, 2004 12:24 AM
