Enigine wont start
Old Sep 22, 2003 | 04:56 PM
D3LSLO's Avatar
Default Enigine wont start
today i had to catch a cab to class bc the engine wont start. THe starter spins and its getting guel but no spark, how can i check the distributer?
Old Sep 22, 2003 | 05:03 PM
poison's Avatar
Default Re: Enigine wont start (D3LSLO)
Are you throwing any codes? How did you check the spark plug?
Take off the distributor cap and inspect the cap and rotor.
Old Sep 22, 2003 | 05:23 PM
D3LSLO's Avatar
Default Re: Enigine wont start (poison)
no code, plugs are fairly new and none of the wires are sending. i pulled the cap off i don't know what to look for, i guess everything looked good, nothing caught my eye
Old Sep 22, 2003 | 05:57 PM
D3LSLO's Avatar
HELP
Old Sep 22, 2003 | 06:05 PM
D3LSLO's Avatar
thats what happened to me, im wont start right now either, and i just did a compression test last night
Old Sep 22, 2003 | 06:54 PM
Green94GSR's Avatar
Don't know any online sources but any cheap manual, Haynes, etc. will have procedure to check the igniter and coil. Might even be able to find one at a used book store if you have one around. Had my coil go out on my civic once, it just died, would turn over just fine, only no spark. Just my 2cents.
Old Sep 22, 2003 | 07:07 PM
poison's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D3LSLO &raquo;</TD></TR><TR><TD CLASS="quote">no code, plugs are fairly new and none of the wires are sending. i pulled the cap off i don't know what to look for, i guess everything looked good, nothing caught my eye</TD></TR></TABLE>
Hmm, remove the cap/rotor and see if you get any spark to the coil spring.
Old Sep 22, 2003 | 08:49 PM
Mochanic's Avatar
yes, its probably a bad coil... if you have a test light, clip the aligator clip to any good ground, and put the sharp end close but not touch the coil on the spring and have someone turn over the engine (with the key) you should see a blue to white spark jump the gap. (not light up the test light!)
Becha don't find any spark!!! This is usually due to the spark plug gap being to wide. (worn out plugs!) This will burn up the coil over time.
Old Sep 23, 2003 | 07:49 PM
D3LSLO's Avatar
Default Re: Enigine wont start (Mochanic)
i took my cap and rotor off tonight, and i gronded a jumper cable (no test light) and got a sprak at the coil spring with that, the spark was really small but was there. should i replace the cap and rotor and see if that does it?
Old Sep 23, 2003 | 10:21 PM
hybridracer504's Avatar
take off one of the spark plugs and plug it in the spark plug wire...then putit down sumwhea where it has has a ground...then try to turn the engine over and see if there is a spark comin from the plug...if there is no spark then the coil is bad...make sure u do not hold the spark plug...cuz if u do ...ull get shocked....
Old Sep 24, 2003 | 07:08 AM
D3LSLO's Avatar
Default Re: Enigine wont start (hybridracer504)
thank you, i will try that and let you know what happens
Old Sep 24, 2003 | 12:13 PM
PupaScoopa's Avatar
You can hold the spark plug all day as long as it and your hand is touching ground.
Ashley Shults
Nov 14, 2016 09:51 PM
1994turbocivic
Feb 10, 2011 06:26 PM
avargas28
Apr 15, 2009 05:32 PM
sohc90rex
16
Dec 21, 2005 09:20 PM
E Swift
Sep 3, 2003 05:46 PM
