Is this engine useable b18c welded in block guard
Old Sep 6, 2007 | 11:15 AM
Cole D's Avatar
Default Is this engine useable b18c welded in block guard
I decided to ask my fellow HTers if this is useable it currently bored 81mm should I bore it 81.5mm or should I scrap it.
http://www.we-todd-did-racing....cqmav
Old Sep 6, 2007 | 11:42 AM
Golden Eagle's Avatar
Default Re: Is this engine useable b18c welded in block guard (Cole D)
you can bore it out if 81.5 will clean up the cylinders but block guards should be installed below the deck for better cooling might get hot spots but you will not know that tell you run it
linkdeezie
Dec 9, 2018 07:35 AM
PARADOX_sf
Sep 1, 2009 01:36 PM
Dee
Dec 4, 2006 12:31 AM
gulftiresinc
Aug 13, 2004 04:12 AM
