Engine Temperatures at the Intake Manifold
Old Jan 13, 2009 | 11:12 PM
AFAccord's Avatar
Icon2 Engine Temperatures at the Intake Manifold
I'm researching composites to find a cheap material to machine intake manifold "spacers" from, and need some solid info on what temps the intake manifold typically sees. I vaguely recall seeing ~205 - 215 degrees when shootng the thermo-housing at idle with an IR temp gun, but I know that number climbs dramatically after some WOT pulls. Any ideas how high? My ECT was reading about 185 at idle, and up to 205 after some pulls, so maybe a 25 - 35 degree increase, or would it be more?
Old Jan 13, 2009 | 11:16 PM
AFAccord's Avatar
Default Re: Engine Temperatures at the Intake Manifold
I've found a glass injected polycarbonate that holds its normal properties up to 315 degrees for long term use. Would this suffice, or should I find something rated higher?
Old Jan 14, 2009 | 07:42 PM
AFAccord's Avatar
Up for some answers.
Old Jan 14, 2009 | 08:05 PM
redboost10's Avatar
do they not make a "hondata" im gasket for your car?
Old Jan 14, 2009 | 08:25 PM
AFAccord's Avatar
No, they do not. But that wouldn't help me anyway because this is not primarily for insulating the manifold, but rather to adapt the ports of a different manifold to the head.
Old Jan 14, 2009 | 08:29 PM
redboost10's Avatar
oh oh i see, sorry. i thought you were just looking for a material to make a gasket out of.
Old Jan 14, 2009 | 08:32 PM
AFAccord's Avatar
Actually I am, but I need a 4"x16" sheet of material that is between 3/8" and 1/2" thick. I having a difficult time finding something that can withstand the head, is easy to machine, and will cost me less than $50 for the small amount that I need.
https://honda-tech.com/forums/honda-accord-1990-2002-2/h23-intake-manifold-onto-f23-head-2411929/
Old Jan 14, 2009 | 08:44 PM
redboost10's Avatar
i was thinking uhmw but it only goes up to about 200 unless you can find the stuff that can withstand up to 350, but its a special uhmw that i dont think will be very cost friendly.
we use uhmw within the blanchers at work, but they only get to about 220 degrees
Old Jan 14, 2009 | 10:55 PM
AFAccord's Avatar
Thanks again for the info. I just found a 12" x 24" sheet of grade XX Garolite for $28 at McMaster, rated up to 284 F. I think I'll give this a try.
mr. carpenter
Apr 17, 2005 07:13 PM
loctoutnicca
Mar 9, 2004 09:33 PM
KStuned
Sep 24, 2003 08:01 PM
