Engine Starting Slow?
Old Jan 4, 2012 | 05:32 PM
Heaven or Hell's Avatar
Default Engine Starting Slow?
Today, I realized it took longer than usual to start my car. Usually I would turn the key for 1-2 seconds and the car would start. This morning, it took 4 seconds while I had the key turned...I was just wondering what this could be a sign of.
If was pretty cold this morning though I'm not sure if this could be possibly related...
Old Jan 4, 2012 | 06:38 PM
tuck1crx's Avatar
Default Re: Engine Starting Slow?
cold makes it very hard for fuel to atomize. there are fuel compensation tables for cold starts but its still tough
Old Jan 4, 2012 | 06:41 PM
hybridmiklo's Avatar
haha. Dont listen to this guy. Take a look at the battery. Do a load test on it. The colder the weather the more work on the battery.
Old Jan 4, 2012 | 08:26 PM
tuck1crx's Avatar
i know exactly what Im talking about. i have my EFI 101 and EFI advanced. but who cares?
battery is a possible culprit though. take a look at that then go from there
Old Jan 17, 2012 | 01:07 PM
I'm sorry if I'm being vague about what I'm about to type...but...
Ok, I read recently somewhere online, someone recommending not to simply turn your car on for a few minutes per week to keep your battery from dying out, because the person was saying carbon in your car will build up? It was something like that. I forget what the post said exactly, but it seemed like it was saying instead of turning it on for a few minutes then turning it off, you should drive around for a while at least.
I'm hoping the above makes any sense...I just don't want this to happen to my new car, even if it's a slight gradual deterioration of some sort.
Thanks for any help...
Old Jan 19, 2012 | 06:18 PM
Old Jan 19, 2012 | 07:08 PM
seanbev24's Avatar
Your last post makes it sound like you rarely drive the car. How often do you drive it?
Old Jan 19, 2012 | 07:10 PM
grumblemarc's Avatar
The Grumpiest
The hatch take s looooong while to start when it's near empty. Top it off and it starts right away.
Old Jan 20, 2012 | 09:53 AM
Not a whole lot but I'll be driving it more when my break's over next week...can you answer my question though?
Old Jan 20, 2012 | 01:56 PM
turbohatch96y7's Avatar
if you don't have a full tank of gas your pump won't build up enough presure in your lines.
If your battery voltage is low your starter won't have enough force to crank your engine and build compression rapidly.. stop asking questions and check either t he battery your gas something this thread been up for a wbhile and your still asking what to do. Check something pleaseeeeeeeeeeeeeeeeeeeee..
And its not carbon its hydrogen forming from electrolosyis (idk if that's spelled right) inside your battery no way to stop this except clean your battery terminals.
Old Jan 20, 2012 | 10:27 PM
seanbev24's Avatar
The best way to keep your battery charged if the car sits is with a trickle charger. Since you asked about that, I figured the car isn't driven much. Since batteries slowly discharge over time and all cars have a slight parasitic drain, slow initial startup is normal if the car hasn't been driven in a while. Cold weather makes it worse.
If the actual cranking was slow before the car started, I'd be looking at the battery and related components.
If the cranking was good and fast, but the engine didn't fire right away, I'd be looking at fuel or ignition components.
Most likely there is nothing wrong. Very cold weather is hard on batteries and fuel. Cars are harder to start when it's cold. If that isn't enough, you need to follow turbohatch's advice and start testing stuff.
Old Jan 20, 2012 | 10:39 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Maybe, but youre way off base here. Learning something and knowing how to apply the knowledge are 2 different things....
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
QFT
Old Jan 21, 2012 | 05:13 AM
The Grumpiest
Originally Posted by DCFIVER
QFT
My battery starts the car right up in the coldest weather.
Old Jan 21, 2012 | 09:52 AM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Yeah but we are doing internet diagnostics. Given the OP's description of the situation,his battery is the most likely culprit....
rovertnamrod
Honda Civic (2001 - 2005)
12
Jul 17, 2013 06:25 PM
mikecp
Dec 3, 2009 12:19 PM
Timberland237
Sep 16, 2007 03:30 PM
wreckedmyteg
Apr 20, 2006 09:23 PM
J2turbo21
Jan 3, 2003 09:11 PM
