Engine Start, But Stop's after 5-10 min...
Old Jun 27, 2006 | 08:25 AM
G0dzArmy's Avatar
Default Engine Start, But Stop's after 5-10 min...
Okay I have a weird problem with my ls-vtec. The engine start, and then it stop by him self after like 5 to 10 minutes, after it as stop I can't start it right away, I have to let the motor rest for like 30 minutes so it can start again for like 10 minutes and stops again...
I know my timing is good.
I tryed 2 differents OBD2 Distributor used.
I tryed 2 differents P28 ECU used.
I just don't know what is wrong with my car...
Problem came after I changed my head gasket for a cometic one.
Modified by G0dzArmy at 5:55 PM 7/12/2006
Old Jun 28, 2006 | 02:50 PM
G0dzArmy's Avatar
Default Re: Engine Start, But Stop's after 5-10 min... (G0dzArmy)
any clue ?
Old Jun 29, 2006 | 11:36 AM
G0dzArmy's Avatar
This problem also came when I installed my AEM 3 bolt Cam gears, Walbro 255lph pump and B&M FPR at the same time I changed my head gasket... I friend of mind tole my about AEM 3 bolts cam gears... it seem that they come loose or something... problem is that the timing is off the camshaft and the timing belt ( crankshaft ).... anyone hear that too?
Old Jun 29, 2006 | 03:51 PM
thesmogman's Avatar
Did you change out the fuel filter?
Cam gears, Threadlock That is what I did.
If your timing is good then...??? No slip.
Old Jun 29, 2006 | 07:04 PM
integralactic's Avatar
try changing out main relay.
Old Jun 29, 2006 | 10:35 PM
Throwdown's Avatar
From: CAPITAL CITY Tallahassee D.S., Florida, U.S.A
Default Re: Engine Start, But Stop's after 5-10 min... (integralactic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integralactic &raquo;</TD></TR><TR><TD CLASS="quote">try changing out main relay.</TD></TR></TABLE> that has been the problem of some weird symptoms in many case's defiantly change that and they are cheap
Old Jun 30, 2006 | 06:16 PM
G0dzArmy's Avatar
Default Re: Engine Start, But Stop's after 5-10 min... (DBL)
For the main relay... It drive the fuel pump I have a B&M Gauge and I can assure you there is no fuel delivery problem.
Timing is good so I guess my cam gears are okay.
Yup I changed my fuel filter (brand new one installed )
I have a other problem that I think is directly related to my ( Engine quit problem )
Okay, it mostly hapen at 5 000 rpm, Check Engine come on for 1 sec and engine stops ( for 1 sec also ) It does that none stop if you keep you feet on the pedal, also my tach is moving like Hells from 1000 to 5000 rpm in my cluster...
They guy at the speed shop said that he think my distributor is the problem... we already tested 2 used one...
Anyone had a problem like that one? check engine come on then engine quit, then restart in a fraction of a sec!
Modified by G0dzArmy at 7:40 PM 6/30/2006
Old Jun 30, 2006 | 08:06 PM
hi-Powered's Avatar
what's your fuel pressure when it doesn't start?
are you getting spark?
Old Jul 1, 2006 | 04:34 PM
G0dzArmy's Avatar
Default Re: (hi-Powered)
don't know it's at the shop right now. I was wondering is anyone had this weird problem befor...
Old Jul 2, 2006 | 10:37 AM
Jago's Avatar
did you switch to the sock from your stock pump. check to se that the pump is pushing fuel to the motor. A friend of mine's car did the same thing. The sock that came on the pump wouln't reach into the bottom of the tank all the way so when it got to be half full it would just start pumping air. if he put gas in it let it sit for a while the sock would soak up some gas and run for a few min. and then go dry again.
Old Jul 3, 2006 | 01:39 PM
G0dzArmy's Avatar
Default Re: Engine Start, But Stop's after 5-10 min... (Jago)
It does the problem even when my tank is full... and it starts at Empty also...
Old Jul 3, 2006 | 04:20 PM
Chiovnidca's Avatar
Main relays very rarely cause stalling problems.
Old Jul 3, 2006 | 04:22 PM
Chiovnidca's Avatar
Default Re: (G0dzArmy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G0dzArmy &raquo;</TD></TR><TR><TD CLASS="quote">don't know it's at the shop right now. I was wondering is anyone had this weird problem befor...</TD></TR></TABLE>
My best guess would be a bad igniter. (if it's loosing spark)
Old Jul 4, 2006 | 06:49 PM
G0dzArmy's Avatar
Default Re: (Chiovnidca)
Yeah I tought that also, but I tryed 2 dizzy maybe both or broken...
Anyone had a problem like that? Check engine come on! then the engine just quits for a second... the code is not recorded in the ECU... that's bad
Old Jul 4, 2006 | 06:59 PM
Chiovnidca's Avatar
Have you checked the ground wire on the t-stat housing? Connection clean and tight?
Old Jul 4, 2006 | 07:25 PM
G0dzArmy's Avatar
ground wire on the t-stat housing? T-Stat What is that... sorry I don't understand
Old Jul 11, 2006 | 07:56 PM
G0dzArmy's Avatar
T-Stat what's that?
Old Jul 11, 2006 | 08:16 PM
PrettyLude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca &raquo;</TD></TR><TR><TD CLASS="quote">
My best guess would be a bad igniter. (if it's loosing spark)</TD></TR></TABLE>
that would be my guess 2, he says the rpms jump from 1000-5000.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G0dzArmy &raquo;</TD></TR><TR><TD CLASS="quote">T-Stat what's that? </TD></TR></TABLE>
thermostat housing
Old Jul 12, 2006 | 02:54 PM
G0dzArmy's Avatar
Default Re: (PrettyLude)
thx... here's an other information, when the engine stop by it self, and you get restart it right away, the check engine light up but not very bright, when it desapire I can restart my engine once again for a few minutes...
tryed out main relay, it's not that.
Modified by G0dzArmy at 5:54 PM 7/12/2006
Old Jul 12, 2006 | 03:20 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G0dzArmy &raquo;</TD></TR><TR><TD CLASS="quote">thx... here's an other information, when the engine stop by it self, and you get restart it right away, the check engine light up but not very bright, when it desapire I can restart my engine once again for a few minutes...</TD></TR></TABLE>
Have you checked the connection of that ground wire yet?
Old Jul 15, 2006 | 09:31 AM
G0dzArmy's Avatar
Nope, I know this groud affect most sensor... it was clean and tight... Okay problem is fix, the shop said so ill post de verdict next week!!!
Old Jul 23, 2006 | 08:31 PM
G0dzArmy's Avatar
Car = Civic hb 93
I had a 1999 B16a2 Head so coverted my distributor harness to OBD-2 to keep my distributor, all worked fine for like a month, then problem came after...
We decided to go back to OBD-1, since I hear they were more problems with OBD-2 distributor... so we ordered a rebuilt delsol 94-95 SIR distributor...
it solve the problem... I really had two OBD-2 distributor with the same damn problem...
crich8136
Honda Civic (2001 - 2005)
Mar 16, 2019 09:50 AM
96accordky
Dec 15, 2009 04:38 PM
Mr. Stiles
Apr 29, 2006 10:02 AM
92HB_HB
Feb 13, 2005 06:05 AM
I8ayellowcrayon
Sep 3, 2003 06:59 PM
