engine problems
Old Mar 30, 2005 | 04:48 PM
ekniner's Avatar
Default engine problems
Friend of mines 92 accord broke down last night. He said it started making some grinding noises then quit. There was oil and anti freeze all over the place including up into the spark plugs. You can here it trying to turn over but when I pulled off the distributor cap the piece inside that rotates to create the spark does not rotate. Any ideas what this could be? Is the motor toast?
Old Mar 30, 2005 | 05:09 PM
jamey220's Avatar
Default Re: engine problems (ekniner)
the oil pump could have went bad and made the cam freeze up in the motor causing the rotor cap not to turn, ive seen it done before, the cam sticks right to the cam caps, pull ur valve cover off and check out the cam.
Old Mar 30, 2005 | 05:45 PM
ekniner's Avatar
Default Re: engine problems (jamey220)
Thanks I will check that out
Old Mar 30, 2005 | 05:46 PM
11sec's Avatar
check the head gasket or find where the oil and the anti freeze came from and there is your problom
EJ1chevelle
Oct 24, 2007 09:40 PM
iNCREDiBLYSLOW
May 23, 2007 07:51 AM
budget
Apr 11, 2006 05:56 PM
user 98292739
Apr 2, 2005 02:42 PM
