Engine lagging under acceleration
Old Dec 31, 2016 | 02:17 PM
Qwqqe's Avatar
Default Engine lagging under acceleration
Hey. So my engine lags hard when I give it gas. It stops reving at around 3k in second gear when I'm giving it full throttle. I have a video here of the problem.
I was thinking maybe a maf sensor, 02 sensor, or maybe something in the fuel system. The car is a 1993 Honda civic and has a D16Z6. Any help would be amazing.
Old Dec 31, 2016 | 02:38 PM
fcm's Avatar
fcm
Old Fart
Default Re: Engine lagging under acceleration
Basic checks...
What is the fuel pressure?
Check both mechanical. [valve] timing and electrical timing.
Use an HEI spark tester to check the spark at each cylinder, [should be bright blue].
Do a compression test.94
Old Jan 1, 2017 | 08:44 AM
B20VtecVillain's Avatar
Originally Posted by fcm
Basic checks...
well I can tell you 100% it's not a MAF issue because your car doesn't have one. First thing I would do is check fuel pressure and take a look at your spark plugs. If fuel pressure is normal, start checking for spark. If you don't have good fuel, then you know it's an injector/fuel pump/fuel filter problem. If it's a spark issue, check plugs, wires, distributor etc.
Old Jan 1, 2017 | 11:42 AM
Qwqqe's Avatar
​​​​​​I will check the fuel pressure tomorrow when I have the chance. When I started it it also smelled like gas. I just changed the fuel pump relay about 2-3 weeks ago.
Jayden1914
Jul 30, 2018 11:34 AM
tarheelsoldier
Mar 15, 2007 08:46 AM
g2turbo
Sep 17, 2003 08:31 PM
Ehron
Feb 21, 2003 07:27 PM
dingusjt
Jul 5, 2002 04:10 PM
