Engine Fan Always Running
Old Apr 14, 2005 | 06:16 PM
wristofice's Avatar
Default Engine Fan Always Running
Hello, new to the forums, Im driving an '89 Accord LX sedan. Problem is the engine fan is constantly running when the car is on. I dont notice any performance problems, just that the fan is loud and always on. Had a mechanic look at it (actually a good guy that Ive taken all my cars to over the years) and he said that its probably some electrical bug that wouldnt be worth the money in labor to track down and that its not a life or death issue for the car. In the short run my concern is that its very loud and distracting from a quiet ride, the long run concern is that I will have to replace it sooner because of its constant use. The only thing Ive done to the car is install a cd player which was done by Best Buy, could they have crossed the wrong wires or something? I really cant remember if the fan was acting the same prior to the install. If anyone has any ideas I'd greatly appreciate them.
Thanks
Old Apr 14, 2005 | 06:57 PM
alpine_hikr's Avatar
Whats your engine temperature guage at? My first guess would be a bad thermo switch or something of that nature if the engine isnt overheating.
Old Apr 14, 2005 | 09:28 PM
PrettyLude's Avatar
install the radio has nothing to do with the fans running, check the thermo switch, or sometimes people hook up relay kits to keep the fans running with the switch
Old Apr 15, 2005 | 07:45 AM
wristofice's Avatar
Default Re: (PrettyLude)
The engine temperature is usually always steady at a little under half way, so I dont think the engine is overheating. Ill do a check on the thermo switch. The guy that owned the car before me did install a remote start, and there is a switch under the steering wheel column that allows for tunring off the remote capability. Maybe I should uninstall the remote start?
Thanks
Old Apr 15, 2005 | 08:35 AM
jsnm's Avatar
it might be more trouble than its worth,but yea,the thermo. switch might be bad(which is located right on the thermostat housing),or it could be some kind of relay issue.
accord4
Jan 21, 2010 05:04 AM
goldenarches69
Nov 12, 2008 10:20 PM
Roster99
Jun 7, 2005 12:40 PM
cr00klyn718
Sep 30, 2002 09:27 PM
