engine damper... good or not ??
Old Sep 7, 2005 | 12:27 PM
yellowturbo's Avatar
Default engine damper... good or not ??
http://www.jdmcarboy.com/engine-dampers1.jpg
do you know if its good. Im getting sick of my insert... its too hard and too much vibration for a street car but with 300whp my engine just move too much with OEM mounts.
Could it be a good solution... and do you know if these are good. I do not trust the website lol
Old Sep 7, 2005 | 12:33 PM
Katman's Avatar
Default Re: engine damper... good or not ?? (yellowturbo)
the engine dampers do work, but it only dampens one side of the engine. Just prevents the motor from upper engine movement...
Old Sep 7, 2005 | 12:41 PM
mmmh the wrote that its for the rear of the engine... if it is mount in the middle I assume that its for the front to rear movement.... ?
Old Sep 7, 2005 | 12:42 PM
they wrote : ''Engine Damper mounts in between your vehicle's engine block and firewall to effectively control horsepower and torque. Keep your motor supported as you slam through those gears while adding a nice show piece under the hood.''
Old Sep 7, 2005 | 04:02 PM
Katman's Avatar
do they have a pic of the damper on the vehicle? because I had a engine diaper..er damper and it only supported the area near the camsprocket side of the head (B18C in EG)..
I'm not denying that it doesn't support the engine, it only supports one side of the engine....while looking kind of cool at the same time. If they now make/have a damper for the tranny side ..then cool..get both!
Old Sep 8, 2005 | 04:10 AM
Default Re: (Katman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Katman &raquo;</TD></TR><TR><TD CLASS="quote">do they have a pic of the damper on the vehicle? because I had a engine diaper..er damper and it only supported the area near the camsprocket side of the head (B18C in EG)..
I'm not denying that it doesn't support the engine, it only supports one side of the engine....while looking kind of cool at the same time. If they now make/have a damper for the tranny side ..then cool..get both!</TD></TR></TABLE>
nan there is no pics but I will email them... to ask for a pic
meno19
14
Aug 2, 2006 03:03 AM
h22 civic
May 31, 2004 02:21 PM
OTT
Feb 10, 2004 02:56 PM
OTT
Feb 10, 2004 08:37 AM
