Engine Cutting Out
Old Apr 22, 2007 | 06:20 PM
JDM91Bseries's Avatar
Default Engine Cutting Out
My brother has a 91 crx with a jdm b16a in it. We recently had to pull the head to replace the headgasket. We redid the timing and everything matches up and is in order. Problem is now that its all together its having a studdering problem. It idles fine and smooth but when u give it gas it starts cutting out until it gets back down to idle. If you barely give it any gas it doesnt spudder till higher rpms..but if you give it more than barely any gas it cuts out. Any ideas? Thanks
Scott
Old Apr 22, 2007 | 06:29 PM
NJIN BUILDR's Avatar
Default Re: Engine Cutting Out (JDM91Bseries)
Check to make sure you didn't plug the wrong wire into the TPS.There are two plugs that will fit,but only one is right.
eM1<3
13
Jan 27, 2010 03:47 PM
vi3tromanc3r
Aug 30, 2008 12:10 AM
Stillo
Oct 15, 2006 10:53 AM
barry11j
28
Dec 6, 2004 11:13 AM
