Engine code problem on 2000 Integra Type- R!
Old Aug 16, 2002 | 07:24 PM
YTYPER's Avatar
Default Engine code problem on 2000 Integra Type- R!
One day my car was shaking when idol, then after few times engine light come on. I checked engine code with snap-on computer, it said P0132 engine code. Did anyone seen that before and how to solve the problem? Thanks!!
Old Aug 17, 2002 | 03:10 AM
PYITR821's Avatar
Default Re: Engine code problem on 2000 Integra Type- R! (YTYPER)
Code P0132 is the Primary heated O2 sensor circuit high voltage (Sensor 1). I am not sure exactly what that means maybe someone else on here can clarify and give advise on how to fix this.
What mods do you have on you car?
[Modified by PYITR821, 12:13 PM 8/17/2002]
Old Aug 17, 2002 | 08:18 AM
B16A1-EF9's Avatar
Default Re: Engine code problem on 2000 Integra Type- R! (PYITR821)
Unplu your primary o2 sensor, rest the ECU and then see if it still does it...it might be just a bad o2 sensor.
Old Aug 17, 2002 | 10:01 AM
YTYPER's Avatar
Default Re: Engine code problem on 2000 Integra Type- R! (brunob16a1)
I have already try to unplug O2 sensor, reset computer. Same problem come out.
Also, i have put a new oem O2 sensor on my car and drive, same problem come out.
[Modified by YTYPER, 1:27 AM 8/18/2002]
[Modified by YTYPER, 1:28 AM 8/18/2002]
spoonzdelsol
Jan 25, 2013 08:04 PM
bigfoot89
Engine Management and Tuning
Dec 21, 2011 05:22 AM
frostee
Nov 19, 2004 04:21 PM
bumthology
Oct 5, 2004 03:18 PM
inzecure1
Mar 18, 2004 10:43 PM
