engine builders opinions
Old Dec 31, 2006 | 09:02 AM
lsvtechatch92's Avatar
Default engine builders opinions
im about to be buildin a piston and rod set up ls vtec 10 to 1 compression eagle rods je pistons... 81.5 mm bore... i will be boosted what do you guys usually put yalls piston to wall clearance at.... and what ring placement and gap do you use.... my crank is fine ...so i should be fine with standard bearings correct... just getting different peopls opinions
Old Dec 31, 2006 | 03:00 PM
DonF's Avatar
Default Re: engine builders opinions (lsvtechatch92)
Whatever JE says.
Old Dec 31, 2006 | 10:11 PM
Combustion Contraption's Avatar
Default Re: engine builders opinions (DonF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DonF &raquo;</TD></TR><TR><TD CLASS="quote">Whatever JE says.</TD></TR></TABLE>
Unless of course, you think you know better than the manufacturer that designed the piston. But then you are just rolling the dice.
Old Jan 2, 2007 | 07:10 PM
JOE BD-0's Avatar
I've been told by a very good source, that piston to wall clearance should be about 1.5/1000ths......good luck
Old Jan 4, 2007 | 10:26 PM
PHDZINE's Avatar
Default Re: engine builders opinions (JOE BD-0)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JOE BD-0 &raquo;</TD></TR><TR><TD CLASS="quote">I've been told by a very good source, that piston to wall clearance should be about 1.5/1000ths......good luck</TD></TR></TABLE>
LOL...if you want to seize the piston to the sleeve...that would be ideal bearing clearance on a street car.
Piston to wall clearance will depend on a few things (Manufacture, piston size, application, ETC.) but you should always use the Job card that comes with the pistons and that will give you what the manufacture recommends but it's usually around .0035 to .004 thousands
Ring gap will vary depending on builder and application but I personally like to run on low boost engines (28 psi max) .019 top ring and .021 lower ring and high boost engines (28-48+ PSI) .024-.025 thousands top ring and .026-.027 thousands on lower ring but this is not set in stone, everybody has there own opinions on whats good ring clearance.
I like to run a little looser than normal bearing clearances in my race and street engines when I build them.
Old Jan 5, 2007 | 05:18 PM
JOE BD-0's Avatar
Default Re: engine builders opinions (PHDZINE)
what's boost?
Old Jan 5, 2007 | 06:21 PM
Some gauge made by autometer.
pornstar4777
Feb 14, 2008 12:47 PM
garyc17
Jun 12, 2007 02:26 AM
lsvtechatch92
Dec 31, 2006 04:46 PM
ozzyman
Mar 26, 2006 07:56 PM
Chillinit
Apr 24, 2005 09:04 AM
