engine balance problem
Old Nov 7, 2005 | 08:08 PM
redlshatch's Avatar
Default engine balance problem
hey everyone, i have a problem with my pistons not being the same weight .....three are 284 and then my fourth one is like 277??? so is there any way to balance that out because i was told that they should at least be within 5 of each other. The reason the one is lighter is because one was dropped and i had to get another one. thanks alot
Old Nov 7, 2005 | 08:29 PM
Jim Truett's Avatar
Default Re: engine balance problem (redlshatch)
They should be within .5 gram of each other, at least in my opinion. I wouldn't run anything less in my engine.
You will need to remove material from the three 284g pistons to make them match the 277g unit.
mmuller's Avatar
Mad Scientist
send out the 3 to a machine shop and get them to match the lightest one
Old Nov 13, 2005 | 06:35 PM
redlshatch's Avatar
will do....thanks for the info
Cho0se
Engine Machining & Assembly
12
Jul 5, 2018 10:09 AM
Code Blue
Feb 24, 2005 09:36 AM
VanHonda
May 6, 2004 08:57 AM
Comtechgsr2000s
Feb 1, 2002 08:55 AM
