engine balance problem
hey everyone, i have a problem
with my pistons not being the same weight .....three are 284 and then my fourth one is like 277??? so is there any way to balance that out because i was told that they should at least be within 5 of each other. The reason the one is lighter is because one was dropped and i had to get another one. thanks alot
They should be within .5 gram of each other, at least in my opinion. I wouldn't run anything less in my engine.
You will need to remove material from the three 284g pistons to make them match the 277g unit.
Comtechgsr2000s
Feb 1, 2002 08:55 AM
