ENeos 0-20 too thin for a built vtec bseries?
Old Oct 15, 2008 | 09:42 AM
oldskool teggy's Avatar
Default ENeos 0-20 too thin for a built vtec bseries?
hi guys.. not sure where to put this, but i was looking at some 0-20 eneos, and thoguht i';d give it a shot, i take my lsvtec to about 9k.. but has anyone else had results with this? i dont want to get into a situation where my ol is too thin, therefore causing any issues with my valvetrain and so forth.
Old Oct 15, 2008 | 11:05 AM
TOO MUCH TORQUE's Avatar
does it burn any oil? if not go for it... i think ow-30 would be better tho
Old Oct 15, 2008 | 02:01 PM
DonF's Avatar
Default Re: (TOO MUCH TORQUE)
Trailored Drag car you are fine, streetcar, Road racing. Not so much.
Old Oct 15, 2008 | 02:08 PM
Default Re: (DonF)
thanks guys.. yeah my 1.8L made 236hp to the hubs at church automotive with a very simple setup on the eneos 0-20. so i was very happy with the power output, but it burned off quick REALLY quick.. thats the only reason i'm worried about what its doing to the inside of the engine..
i'm going to try castrol euro formula 0-30 and see if it helps.. and yes its a street car
Old Oct 15, 2008 | 04:58 PM
1992Si's Avatar
IMO why waste the money on that oil ?
Any good 10w30 should be fine. It's is a street car and subject to all kinds of adverse conditions a race engine never sees.
Old Oct 16, 2008 | 06:15 AM
Boner_Ben's Avatar
Default Re: (1992Si)
Eneos is good stuff, for racing I would use there 0w-50 oil.
Old Oct 16, 2008 | 11:11 AM
patriot's Avatar
I wouldnt recommend a 0W-anything for a daily driver. I'm a fan of Pennzoil Platinum 5w30. It has a slightly higher burn off rate than Castrol but but has a much higher sheer level. Why would you want to use anything other than what Honda recommends?
Old Oct 16, 2008 | 11:46 AM
Default Re: (patriot)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by patriot &raquo;</TD></TR><TR><TD CLASS="quote">I wouldnt recommend a 0W-anything for a daily driver. I'm a fan of Pennzoil Platinum 5w30. It has a slightly higher burn off rate than Castrol but but has a much higher sheer level. Why would you want to use anything other than what Honda recommends? </TD></TR></TABLE>
0w is better for start up protection.....about 90% of engine wear is due to start up
Old Oct 18, 2008 | 12:21 AM
EnjoyTheRideDC2's Avatar
Default Re: ENeos 0-20 too thin for a built vtec bseries? (oldskool teggy)
0w-20 is too thin IMO... I wouldn't run anything lower than 0w30. But 5w30 is fine for B series engines. is a 5w that much harder than a 0w on startup?
Old Oct 18, 2008 | 08:24 PM
i'm going with the 0-30 castrol euro formula..
thanks guys.. BTW. i have 5 quarts of e-neos 0-20 for sale.. now
dester223
Sep 24, 2013 07:03 PM
chris2000
21
Dec 30, 2006 09:04 PM
TheHeyta
10
Feb 18, 2003 11:30 AM
JSIR
Jun 15, 2002 04:18 PM
eMoTiOn_EnGiNe
Aug 3, 2001 08:22 PM
