Emissions? Is Valve overlap a major contributor to emissions issues?
Old Aug 7, 2002 | 10:19 AM
Spade's Avatar
Default Emissions? Is Valve overlap a major contributor to emissions issues?
I am just wondering. Turbo cams have minimal valve overlap for full on burns....therefore I would think that they would have less issues of emissions failures......Just wondering if I am thinking in the correct direction of am I totally off.
Old Aug 7, 2002 | 11:46 AM
fastbrakes's Avatar
Default Re: Emissions? Is Valve overlap a major contributor to emissions issues? (Spade)
The increase in valve overlap will dilute the incoming fuel mixture as well as allow some of that charge to be sucked out of the exhuast side. At low RPM the overlap is the main reason for higher emissions. That's why high overlap cams make the engine 'chug' at idle speeds that are too low to allow the rich mixture to burn properly....
jceltalentoso
K Series
Jan 27, 2014 06:45 AM
Honda-bond
32
Jan 22, 2011 02:45 PM
mhewitt
Sep 16, 2010 10:51 AM
exownzu
Sep 30, 2006 08:58 AM
