emissions help! throwing 13 codes!
Old Jan 27, 2006 | 08:31 AM
blackie's Avatar
Default emissions help! throwing 13 codes!
so i got the obd2 scan today at the auto zone. the thing read 13 codes being thrown on my car. first off, i drive a 99 civic ex with a 99 usdm gsr swap. i used my ex wiring harness and the ecu is a 99 si ecu. the codes that are being thrown are:
-P0301
No. 1 Cylinder Misfire
-P0302
No. 2 Cylinder Misfire
-P0303
No. 3 Cylinder Misfire
-P0304
No. 4 Cylinder Misfire
-P0131
02 sensor low volts bank 1 sensor 1
-P0500
speed sensor A malfunction
-P0135
02 sensor heater malfunction bank 1 sensor 1
-P0171
system too lean
-P0141
02 sensor circuit malfunction bank 1 sensor 2
-P0300
multiple cylinder misfire
-P0170
fuel trim malfunction bank 1
here the complete list from the scan. can someone pleaaaase help me out.
i reposted here cause i guess the '92-00 Civic / Del Sol wasnt the best place
Modified by blackie at 7:59 PM 1/27/2006
Old Jan 27, 2006 | 10:52 AM
onepoint6i's Avatar
Default Re: emissions help! throwing 13 codes! (blackie)
replace your o2 sensor.... assuming your wireing is working well and intact..
Old Jan 27, 2006 | 07:00 PM
blackie's Avatar
bump for me
Old Jan 27, 2006 | 08:33 PM
blackie's Avatar
anyone? i think half of the problems would be gone if i got the correct usdm 99 gsr ecu but dont they have the immobilizer?
Old Jan 27, 2006 | 09:19 PM
boosted k20's Avatar
Default Re: (blackie)
RESET your ecu and check the codes urself. dont waste ur time go n to autozone for that ****. if the car is throw n CEL for misfire, did u ever crank the car with the dizzy not plugged in? that will throw those codes. it could also be that the plugs r no good. do a tune up on the car (Plugs, plug wires, cap, rotor)
also when u did the swap did u install the O2 sensor????
Old Jan 28, 2006 | 07:44 AM
onepoint6i's Avatar
take it to someone that knows what they're doin
Old Jan 28, 2006 | 06:57 PM
blackie's Avatar
i think i might need a tune up. anyone else with some good info? ill try reseting the battery also
Old Jan 28, 2006 | 10:21 PM
blackie's Avatar
is the 99 gsr ecu obd2b? and does it have the immobilizer?
Old Jan 29, 2006 | 11:41 AM
blackie's Avatar
sunday bump
Old Jan 29, 2006 | 06:11 PM
blackie's Avatar
bumpin for a reply
TravisCadello
14
Feb 6, 2013 07:40 AM
willpoorman
Feb 27, 2010 06:02 AM
1badteg
Feb 23, 2010 01:52 PM
blackie
Jan 30, 2006 08:06 AM
