ef w/ob1 po6 pin a23 gnd questions
Old Apr 7, 2012 | 06:36 PM
rstchris's Avatar
Default ef w/ob1 po6 pin a23 gnd questions
I have a 90 hatch with mpfi and obd1 conversions. The car runs perfectly until the drivetrain gets a shock. It's got a nasty clutch in it and when I do a hard 1-2 shift or sometimes when I roll into 1st or 2nd gear and it hooks up the engine stalls out. Sometimes it comes right back in and sometimes it decels until I cycle the key off/on.
I hooked up a tst light to ecu ig+ and all the gnds 1 at a time and obd1 pin a23 is in question. (obd0 pin a2) At idle I see a very dim lit test light, as the rpm goes up it gets brighter and when I gnd the wire the engine stalls and wont start back up. The diagrams I looked up all ay that it's a gnd.
Can anyone verify that this is normal or if I found a problem?
Old Apr 11, 2012 | 02:35 PM
rstchris's Avatar
Default Re: ef w/ob1 po6 pin a23 gnd questions
Can someone test this pin on their car and verify? Please?
Jdmefsir12
Jul 1, 2012 08:13 PM
griffinjr123
Mar 9, 2009 07:43 PM
Ruben19
Dec 13, 2008 06:49 PM
