ECU's?
Old Jan 26, 2003 | 08:18 AM
devonic's Avatar
Default ECU's?
I got a question about ECU's
will a manual Ecu in a Automatic Car work? will it cause any problems? doing a mini me swap and just got an ex ecu but i think its manual
Old Jan 26, 2003 | 08:42 AM
Malgerus's Avatar
Default Re: ECU's? (devonic)
Uhhh well, Auto ECU's (esp. the OBD-I) ones have provisions for parts that only an automatic transmission has. I know because when I tried to use an auto p28 with my M/T CRX I got codes. So if you have an auto, get an auto ECU.
Old Jan 26, 2003 | 09:21 AM
devonic's Avatar
ttt
[Modified by devonic, 11:23 PM 1/26/2003]
Old Jan 26, 2003 | 02:23 PM
devonic's Avatar
bump
Old Jan 26, 2003 | 02:42 PM
ce's Avatar
ce
No it wont work but you can convert auto to manual and vice versa..Look at http://www.zdyne.com ..Click on tech...
Quote: After identifying a ECU as from an automatic transmission car, it can be converted to a manual by adjusting the ECU's configuration jumpers (P28 Civic D16Z6 shown).
Old Jan 26, 2003 | 02:48 PM
devonic's Avatar
Default Re: ECU's? (ce)
so all i can do with this is probly sell it and find a auto then right?
Old Jan 26, 2003 | 05:20 PM
devonic's Avatar
oh well...anyone need a 97 EX MAnual ECU?
Old Jan 26, 2003 | 06:51 PM
ChiBoy's Avatar
No, you can convert it to manual like CE said. It's just a couple of resistors on the ECU board.
Old Jan 27, 2003 | 11:22 AM
Joseph Davis's Avatar
Default Re: ECU's? (ChiBoy)
*uNF*
Most OBD1 chippers drop the correct program into the ECU and don't fiddle the jumpers when going from auto to manual.
You could probably limp the weak auto maps by shuffling resistors, as they are nothing more than hardware configuration jumpers, but the correct solution is the correct program for the engine.
In the case of the poster with the OBD2 ECU... unhm, good luck. Hondata is about the only person who touches those, and you could buy OBD1 P28 and conversion harness for less than they'd want and do your own auto to manual conversion.
[Modified by J. Davis, 12:24 PM 1/27/2003]
valleyhatch
Feb 1, 2008 10:01 AM
B18Cej1
Sep 10, 2006 01:39 PM
lv6l
10
Dec 10, 2005 10:09 PM
kevgnuboy
Apr 3, 2003 08:26 AM
hondafrk
Feb 22, 2003 08:58 PM
