ECU Question..?
Old Jul 3, 2003 | 12:22 PM
eg6h8k's Avatar
Default ECU Question..?
hey
i got a 92 hatch w. a 2nd gen b16a w. a p30 ECU
ever since my swap my ecu is throwing code 23..which is the knock sensor..
i'm not gonna bother to get rid of it..cuase i'm gonna get a chip ecu anyways..
my question is in the mean time..will this throw my ECU into LIMP mode? cuase now i get such shitty gas mileage....i swear i can see my needle go down..the motor seem to run really strong though..any thoughs?
Modified by eg6h8k at 9:38 PM 7/3/2003
Old Jul 3, 2003 | 01:22 PM
Prelude Vtec 23's Avatar
Default Re: ECU Question..? (eg6h8k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6h8k &raquo;</TD></TR><TR><TD CLASS="quote">hey
Modified by eg6h8k at 9:38 PM 7/3/2003</TD></TR></TABLE>
Its not that hard to fix, you said that this has happened ever since the swap right? Well I had this about a week ago and the problem was bcuz the sensors were swapped w/ each other. On the back of the block there are two connectors that are exactly the same and can be interchanged w/ each other. One is the knock sensor and the other I believe is the heated o2 sensor. Just go underneath the car and swap the two. Its in the middle of the block on the back side of the motor (knock sensor) and the heated o2 should be across from that closer to the firewall.
Hope thats the problem
Old Jul 3, 2003 | 01:31 PM
eg6h8k's Avatar
Default Re: ECU Question..? (Prelude Vtec 23)
hmm son of a bitch..i didnt know that theyre the same..ok let me try that..thanks man
Old Jul 3, 2003 | 01:56 PM
eg6h8k's Avatar
well i checked and it seems to be fine..i think my knock is dmg or something..but does anyone know if it goes into limp mode..?
Old Jul 3, 2003 | 01:58 PM
Katman's Avatar
you can also have your P30 ecu reprogrammed with a program which has a disabled Knock Sensor. Hit me up if you'd like to do this
Old Jul 3, 2003 | 02:02 PM
eg6h8k's Avatar
Default Re: ECU Question..? (Katman)
ahh Katman i was gonna email u about the ecu thing..i saw u on jdmhonda...but someone had mentioned that p30 are alot harder to program then p28..? so i was gonna get a p28 chipped..is it true?
Old Jul 3, 2003 | 02:04 PM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6h8k &raquo;</TD></TR><TR><TD CLASS="quote">ahh Katman i was gonna email u about the ecu thing..i saw u on jdmhonda...but someone had mentioned that p30 are alot harder to program then p28..? so i was gonna get a p28 chipped..is it true?</TD></TR></TABLE>
not true at all.
I can easily reprogram any OBD1 ecu whether it be JDM, US, or Euro spec.
Some people can't reprogram the small JDM P30 ecu's because their ecu-parts resources are limited.
eghatch77
Dec 26, 2011 10:07 PM
anthonydaman
Sep 23, 2010 04:20 AM
xcon0570
Mar 1, 2008 07:54 AM
honda4674
Apr 5, 2006 08:05 PM
kahren
Mar 8, 2002 01:54 PM
