Ecu pin removal ideas ?
Old Feb 2, 2003 | 11:17 PM
RCautoworks's Avatar
Default Ecu pin removal ideas ?
If you ever removed the ecu pins, then you know how hard it could be. Well I was thinking about what I could make out of home made stuff or buy. I saw these at harbofreight.com
I also heard gridning a nail down works, well any help. Anyone know where I could get a honda pin removal tool ?
Old Feb 3, 2003 | 12:58 AM
brinks's Avatar
Default Re: Ecu pin removal ideas ? (90blackcrx)
Eyeglass screwdriver. Get it locally. Try a store
Old Feb 3, 2003 | 06:04 AM
tnbigdawg's Avatar
Default Re: Ecu pin removal ideas ? (brinks)
i used a paperclip
Old Feb 3, 2003 | 06:30 AM
Hondasaurs's Avatar
I used an identical harness with the pins already in it. It was a little time consuming to splice it in but this way I knew my connections were good.
Old Feb 3, 2003 | 07:25 AM
qtiger's Avatar
Default Re: Ecu pin removal ideas ? (ZC_CRX)
I just used a Field's AFC harness. Every pin has a wire, all you do is splice to the wire.
A bit expensive, but relatively simple and you're assured of good connections. Plus you don't have to hack up your stock harness.
Mikey3000
Jun 24, 2008 04:59 PM
85mm LS VTEC
Mar 11, 2005 05:10 PM
cr00klyn718
Jul 13, 2003 10:59 AM
greebler
May 12, 2003 10:53 AM
