ecu code problems
Old Nov 19, 2002 | 12:00 AM
gsR*sonic's Avatar
Default ecu code problems
sup guys..i have recently installed some itr headers and exhaust on mah 99 gsr and after that my car started to idle funny and the ride was all weird....then after 2 weeks ago my engine check light came on and i checked the codes and it was 45 which meant the system fuel is too rich or lean.......wut could be the problem? o2 sensor possibly?
Old Nov 19, 2002 | 09:00 PM
dr650's Avatar
New User
Default Re: ecu code problems (gsR*sonic)
o2 sensor mostlikely<<check ur connection<<
Old Nov 19, 2002 | 09:13 PM
Fuuma0083's Avatar
Default Re: ecu code problems (dr650)
agreed
Old Nov 19, 2002 | 11:08 PM
T25 civic's Avatar
Default Re: ecu code problems (Fuuma0083)
You might want to reset the ecu and let it relearn before driving it. The ecu needs to relearn and adjust for 10-15 minutes to each change with intake/headers/exhaust that you make. To relearn you unplug the battery to reset the ecu. It usually takes 10-15 minutes on my car. Then plug it in and start your car. Don't have the stereo on, headlights, air, any power drawl at all. After 15 minutes take it for a spin and see if that helped any.
HTH
Nick
Old Nov 19, 2002 | 11:23 PM
gsR*sonic's Avatar
Default Re: ecu code problems (T25 civic)
well i already rested mah ecu like 3 times already, didnt help......the funny thing is mah check engine light went off......but im still having problems.......i honestly think is mah o2 sensor......but who knows......thans ne way guys
Old Nov 19, 2002 | 11:50 PM
CivicVTi182's Avatar
I am having exactly the same problem...car idles bad but runs good up to 1500 rpm....reseting the ECU made the engine light off b ut didn't help so I changed my O2 sensor....runs good now
Old Nov 20, 2002 | 12:13 AM
T25 civic's Avatar
mah=my? sorry not up on the ebonics lol
BoostJockey
23
Feb 7, 2014 04:42 PM
Hardedge
Feb 11, 2008 12:32 AM
arychel
Mar 15, 2006 08:20 PM
bo0sted
Sep 17, 2004 02:53 PM
SupaSh0ck
Jan 19, 2003 01:39 PM
