ECU CODE 10??/
Old Apr 27, 2007 | 09:42 AM
tshuajzoo559's Avatar
Default ECU CODE 10??/
i HAVE A 93 CIVIC DX...LAST NIGHT JUST PUT IN A 91 LS MOTOR INSIDE...I HAVE A CODE 10...NEED HELP WAT IS IT?? i'm running ls ecu.
Old Apr 27, 2007 | 09:51 AM
For Hybrids's Avatar
Default Re: ECU CODE 10??/ (tshuajzoo559)
intake air temp sensor
Old Apr 27, 2007 | 10:05 AM
slomofo's Avatar
GDD Member
You probably mixed the plugs up between IAT and EVAP. If this happened, you can pull your ECU cover off and see where the EVAP pin burned out. You'll have to resolder the pin for the EVAP unless you don't care which most people don't.
hollywoodciv
Feb 10, 2004 12:27 PM
DarkZachiel
Oct 19, 2003 09:30 PM
OnePointFive
May 1, 2003 08:04 PM
See Are X
Aug 19, 2002 03:07 PM
