dumb question about removing the wrist pin...
Old Jun 11, 2003 | 08:29 PM
SLOW4drINTEG's Avatar
Default dumb question about removing the wrist pin...
HOW DO YOU REMOVE IT?!?!?! we tried to machine press it out...no luck.... bare with my noobiness
Old Jun 11, 2003 | 09:30 PM
b19coupe's Avatar
Default Re: dumb question about removing the wrist pin... (SLOW4drINTEG)
Honda has a special tool for that job-it's what I use; that and a press. I don't know how the guys that don't have the tool do it.
Old Jun 11, 2003 | 10:16 PM
Default Re: dumb question about removing the wrist pin... (b19coupe)
do u have the special tool plus the "piston tool base"? *been reading helms* hahah
anyone else does it diff?? thanks!!!
Old Jun 11, 2003 | 10:25 PM
b19coupe's Avatar
My shop does. You have the base + a couple of attachments. It is a pretty trick setup. The piston only goes on one way though; I found out the hard way and cracked one of my pistons . My JE's with full floating wristpins were much easier to install
Old Jun 11, 2003 | 10:59 PM
irev210's Avatar
*drool* full floating wrist pin
all motors should come like that from the factory.
Old Jun 12, 2003 | 09:49 AM
got it done!! went to my bro's fren's shop...your suppose to heat it up over 180 degree (dur) and the rod will expand which alows you to press it out...
yeah def free floating wrist pins stupid CTR pistons...hahaha
thanks for the help!!
jasonALYK
Oct 20, 2011 10:18 AM
SaM DA Man
Dec 16, 2006 07:15 PM
kublai
Aug 16, 2005 05:31 PM
Ri5e
Sep 7, 2002 07:24 PM
GruvyTune
Jul 16, 2002 09:14 PM
