Driving With MIssing bolt in valve cover
Old Apr 27, 2003 | 01:49 PM
steve_s's Avatar
Default Driving With MIssing bolt in valve cover
I broke a bolt or is it a stud? in my valve cover. THe engine is a D16Z6. THe bolt (stud) was the one in the top left. Can i drive for about a day with only that one missing until i goto honda to get a replacement?
Old Apr 27, 2003 | 04:29 PM
hatchdrvr's Avatar
Default Re: Driving With MIssing bolt in valve cover (steve_s)
as long as you keep a case of oil in your car because it is going to spill a lot of oil and make a huge mess.
Old Apr 27, 2003 | 04:35 PM
MrTodd's Avatar
Default Re: Driving With MIssing bolt in valve cover (hatchdrvr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchdrvr &raquo;</TD></TR><TR><TD CLASS="quote">as long as you keep a case of oil in your car because it is going to spill a lot of oil and make a huge mess.</TD></TR></TABLE>
He's not joking either... The D16Z6 valve cover uses bolts BTW, not studs. On my old D16A6 motor, (uses studs for valve cover) I broke the top left stud by tightening it too tight. When I started up the motor, you could actually see the oil spitting out from the top-left corner of the cover - and there was a LOT of it.
I would highly recommend buying a new bolt before you go around driving it anywhere.
99accordsedanforsale
Classic Hondas
Nov 12, 2007 07:24 AM
97civic123
Feb 18, 2007 06:46 AM
islander27
Apr 25, 2004 09:33 PM
miksew
Dec 26, 2003 09:42 AM
HarryB
Sep 6, 2002 09:29 AM
