Drill and tapping to the next size up
Old Sep 5, 2024 | 05:44 PM
CastleRedEH's Avatar
Default Drill and tapping to the next size up
I was tearing down some integra rear trailing arms and when I got to the 10mm bolts that hold the dust shields on, I had two that broke at the heads. So my question is what would I drill and tap the next size up? a 12mm bolt? if so what is the pitch?
Thanks in advance.
Old Sep 5, 2024 | 09:42 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Drill and tapping to the next size up
8mm x 1.25 pitch. I am not sure if you can move up to this size from the 6mm x 1.00 pitch bolts that are broken off in your Integra rear trailing arms.
Old Sep 6, 2024 | 02:38 PM
Thank you. I will try.
M.
twentyhurtz
May 9, 2009 11:41 PM
radeonboy
Apr 5, 2006 06:45 PM
MI4$DC5
Apr 16, 2005 09:24 PM
Beatkidd
Dec 28, 2003 10:07 PM
bigslimdog
May 2, 2003 08:47 PM
