Double-Check Torques
Old Mar 28, 2003 | 10:53 AM
ion_four's Avatar
Default Double-Check Torques
Can someone give me the correct torque specifications (from Helms) for the flywheel/pressure plate etc. on a 93 Civic EX (d16z6)? I only have the Haynes manual and I don't trust it for something like this.
Thanks in advance!
Old Mar 28, 2003 | 12:10 PM
poison's Avatar
Default Re: Double-Check Torques (ion_four)
The flywheel bolts to the crank is 87 lb-ft
The pressure plate bolts to the flywheel is 19lb feet.
This is off the Helms.
Old Mar 28, 2003 | 03:34 PM
ion_four's Avatar
Default Re: Double-Check Torques (poison)
THANK YOU!
I figure most things only need to be approx., but this is something that definitely needs to be right! Interestingly...I was having some major troubles with my oil pan weeping (replaced the gasket 3 times) and finally spoke to some "real" honda-techs and they told me to shove the torque specs and just do it with a 1/4" wrench, making LAPS or 1/4 turns (not star pattern) around the pan until it's finder tight...just to share a tidbit
Thanks again! Just to make sure, that's for the d16z6 tranny (whatever it is)?
Also, the ACT site says I should have my flywheel stepped "Down 0.065" what does this mean? Will NAPA (or whoever resurfaces it) know what the hell to do with this?
[Modified by ion_four, 12:40 AM 3/29/2003]
Old Mar 28, 2003 | 03:59 PM
poison's Avatar
Yes, that's for the D16Z6 tranny (S20).
For the ACT stating to have the flywheel stepped "down .065", I'm not too sure.
I would need more information on exactly what it says before I throw some answers. If you bring what it says, I'm sure a NAPA employee will know what it's referring to, but from the information you said, there isn't enough for me to throw and answer..
HTH.
TeinEM2
Aug 4, 2011 07:38 AM
iCollectStraws
Transmission & Drivetrain
Oct 17, 2009 07:18 PM
danthemang3
Jun 20, 2009 11:37 PM
madswapper
May 1, 2005 05:01 PM
Zornig
Jun 26, 2004 10:19 AM
