Does vtec not work if Ecu goes into limp mode
Old Nov 29, 2004 | 05:54 PM
BoRiCuA's Avatar
Default Does vtec not work if Ecu goes into limp mode
I heard that if i'm getting a check engine light , the ecu goes into limp mode and vtec won't engage is this true?
Old Nov 29, 2004 | 05:58 PM
Kamin's Avatar
Default Re: Does vtec not work if Ecu goes into limp mode (BoRiCuA)
yes. but not all check engine lights will put the ECU in limp mode.
Old Nov 29, 2004 | 06:01 PM
BoRiCuA's Avatar
Default Re: Does vtec not work if Ecu goes into limp mode (Kamin)
will a code 10 oxygen sensor put it in limp mode?
Old Nov 29, 2004 | 06:03 PM
Kamin's Avatar
no.
code 10 is not the O2 senro tho
code 1 is, code 10 is the intake air temprature sensor
Old Nov 29, 2004 | 06:11 PM
BoRiCuA's Avatar
ok well i get the 1 long blink when checking for codes is that the intake air temprature sensor? if so will it cause limp mode?
Old Nov 29, 2004 | 08:44 PM
racinategra's Avatar
what codes do put ecu in limp mode. IM throwing like 3 and I my vtec hits, let me tell you it hits. The new M3 driver i found on the freeway will tell you it hit on him too! BUMP FOR VTEC.
Im throwing the dist. code, knock sensor and O2 sensor.
Old Nov 29, 2004 | 08:53 PM
drdisco69's Avatar
Default Re: (racinategra)
True limp mode is a very unpleasant thing: 3000rpm rev limit, unbelievable studdering, no power at all. Safe mode or whatever you want to call it is different, just giving more fuel and a little less timing. If your ecu was in limp mode, you would know, trust me. There's not much short of an internal failure that will cause it though. As far as the safe mode not letting vtec work, I'm not sure how much has to go wrong. Obviously a lot if 3 codes allow it to engage.
Old Nov 30, 2004 | 01:09 PM
BoRiCuA's Avatar
Default Re: (drdisco69)
Where should i start to check to find out why v-tec isn't working?
Old Nov 30, 2004 | 01:11 PM
Kamin's Avatar
Default Re: (BoRiCuA)
http://info.honda-tech.com/ind...oting
Old Nov 30, 2004 | 01:23 PM
BoRiCuA's Avatar
Default Re: (Kamin)
Thanks for the link , i'll look into it.
1clean_ Ej
Feb 28, 2007 08:07 PM
vtecpsyco
Oct 23, 2005 11:18 PM
fsck3r
Aug 17, 2003 11:46 PM
fOmaNPu
10
Apr 23, 2003 09:31 PM
CLICC916
Feb 26, 2002 06:00 PM
