Does this REALLY reduce Wheel Hop in Teg?
I read a review that said the the Z10 Radius arms Eliminated wheel hop and reduced bump steer in the EG hatch.
Do you know if it will work for my GSR sedan?
I emailed them but maybe you guys know better?
Anyone have firsthand experience with this product?
Thanks in advance.
Thanks in advance.
the z10 radius arms work great (i dont speak from experience, i speak from what ive seen/heard)
let me see if i can find the website
im planning to get a pair for my coupe
The product really works as advertised. from my understanding it should fit on your car without problems. while going poly engine mounts is cheap and does eliminate the dashboard type vibration called wheelhop, it doesn't prevent the side to side motion that still exists with the poly engine mounts. the side to side motion known as tire shake is eliminated with the z 10 bars. if you car is an older car, your lower control arm bushings are probably worn out, and this condition makes tire shake even worse.
previously on my car my bushings we're so worn that when i stepped on the brake hard, it would actually wheel hop while decelerating. this was because the lower control arms would ocillate, and that motion would be transfered to the motor from the axles. when i put the z 10 bars on this no longer happened.
i have them, yes they work, since your search button is broken heres a link to the post that discussed this FROM 2 DAYS AGO https://honda-tech.com/zerothread?id=119926
heres more info that reviews and desribes the install http://hybrid.honda-perf.org/tech/z10.html
elitesi8
Oct 9, 2005 06:42 AM
