Does my mainrelay look okay? (pics)
Old Apr 6, 2003 | 03:33 PM
hatchy's Avatar
Default Does my mainrelay look okay? (pics)
It looks fine to me, but I am having hot start problems and this is on my list of things to check.
[Modified by hatchy, 4:34 PM 4/6/2003]
Old Apr 6, 2003 | 06:32 PM
Turbo Powa's Avatar
Default Re: Does my mainrelay look okay? (hatchy)
Hot start problems... you would need to check your air filter on your intake and make sure its clean with no blockage. Also check for loose or deteriorated grounds and replace if necessary. You should also check your spark plugs and ignition system.
Old Apr 6, 2003 | 07:00 PM
jeffreytard's Avatar
Nice picture.
Look very closely on the solder joints for a very fine line around the protruding pin.
It will look like a circle was drawn around it with a very fine tip pencil thinner than a strand of hair. If you see one thats your break and thats why it won't start when interior is hot and when it cools down and contracts back together will start.
I hope I made sense.
Old Apr 6, 2003 | 10:41 PM
hatchy's Avatar
Default Re: Does my mainrelay look okay? (jeffreytard)
Yeah, I think I know what to look for, but looking at the joints, I dont see any cracks at all. But I am still having hot start problems. It is possible that the failure is at the relay itself, and not the joints?
Old Apr 7, 2003 | 06:20 PM
speedaccordinly24's Avatar
does the relay have to have cracks in the solder joints in order to be bad? because mines looks fine, but i tested it and it has no continuity.
Old Apr 7, 2003 | 10:19 PM
hatchy's Avatar
Default Re: Does my mainrelay look okay? (speedaccordinly24)
Well, I replaced mine today, and so far so good. I'll know more tomorrow during the day when it is warmer.
Old Apr 8, 2003 | 04:29 AM
Honda Hick's Avatar
I had the same problem with my integra. Only in the hottest weather it would not start and it did it whenever it felt like it; ex. At the gas station . Everyone's staring at you cuz your cranking the **** out of your car. It did turn out to be the main relay. Instead of messing around with it, I just bought a new one for like $30.
Been workin fine since.
Old Apr 8, 2003 | 07:59 AM
Charlie Moua's Avatar
can you tell me where i can find or locate it?(90 civic si)
do i have to take off any bolts?
where can i take it to be tested?
OMGdjdy
Jun 23, 2010 12:30 PM
spetka
Mar 24, 2007 02:45 PM
hurleyboarder21
Apr 12, 2004 07:22 PM
JDMlyfestyle
22
Jan 9, 2004 10:36 AM
Johnny Tran
May 22, 2002 05:51 AM
