Does anyone Need help with... Anything?
Old Feb 13, 2012 | 02:04 AM
  #26
mouab18c1's Avatar
Default Re: Does anyone Need help with... Anything?
Originally Posted by Marior82003
I need help with my engine. Doesn't get a spark. I've been searching the threads and I've tried pretty much everything and still no spark. I have a b16a2 with an obd1 ecu and obd1 harness. But here's the kicker. I have an obd2 distributor and a crank sensor down toward the shaft. Here's my question. Does the obd2 distributor need the signal from the crank sensor to give off spark? Cause i was told I didn't need the sensor since it was obd2. Thanks in advance if someone can help.
To answer your question no, it does not read off the CFK sensor. Since you have an obd1 ecu it won't even be looking for it. Since you are running an obd2 distributor on an obd1 harness, I would double check your wiring.
Old Feb 13, 2012 | 04:07 AM
  #27
MastaTech's Avatar
Originally Posted by winemaker2
I have an electrical fuse ? posted on the CR-V forum so I won't duplicate it here. Do you know of any sources for electrical schematics for a 2995 CR-V? My post deals w/ parasitic loads for fuse #8 radio/assy & # 18 Fr power socket.
I'd appreciate any assistance or links to explore.
Thanks
what year cr-v??
Old Feb 13, 2012 | 04:08 AM
  #28
MastaTech's Avatar
Originally Posted by mouab18c1
Sometimes my motor won't crank/turn over at all. Then it will be fine again. HELP me ahah
could be an intermitent failure of you starter solenoid. try tapping it with a hammer next time it wont start then see what happens
Old Feb 13, 2012 | 04:09 AM
  #29
MastaTech's Avatar
Originally Posted by FlewByU352
Randomly my car won't start, then sometimes while driving the car shuts off as far as electrical like radio and cluster where the tach drops to 0 but since the alternator is still turning I assume the car still runs. I checked voltage everywhere, checked grounds, the only thing I could come up with is the ignition switch is going?
what are you driving?
Old Feb 13, 2012 | 04:15 AM
  #30
MastaTech's Avatar
Reply to 2002 civic missfires. i have seen a lot, and i mean a lot, of head gaskets let go in those cars. creates missfires while then engine is hot or when first started. have you been watching your coolant level? not temp gauge but your actual fluid level?
  #31
grumblemarc's Avatar
The Grumpiest
^^^Advice. If you're only going to be on here every 10 days you might want to rethink your offer to help.
Old Feb 13, 2012 | 04:18 AM
  #32
MastaTech's Avatar
Originally Posted by 2low93
I have an 93 civic ex... the past few days i have notice that when i start my car up when it cold it idle at 3 grand but once warm it goes to normal what could be wrong with i have ran out of reason!!! help plz
if youre coolant level is low that could cause i high idle sometimes. have you checked the level??
Old Feb 13, 2012 | 04:21 AM
  #33
MastaTech's Avatar
Brand new battery.
have you checked all your ground for corrosion? there are a couple ground straps that ground the engine and since the engine is the ground for the starter they need to be in good shape. usual suspect for your car is the one on top of the radiator support
Old Feb 13, 2012 | 04:25 AM
  #34
MastaTech's Avatar
Originally Posted by mattyrocks785
WHERE ARE YOU!?!?!? jeebus. opening a "does anyone need help with anything?" thread here is like sending a naked woman into a room full of rapists. I got car problems, i need more money, i cant figure out how to change the fog lights on my damn 06 pilot, my garage door lights arent working AND my ambien doesnt work anymore so im awake at 3:30 am! HELPPPP
Sorry! family emergencys come first in my house. anywho, are you changing a bulb or whole assemply for your fog light? your ambient LED is probably fried. unfortunately they arent serviceable, you need the whole assemply up there. (assuming you meant the one on the roof liner, not the one under the radio?) or are you reffering to your ambient temp?
Old Feb 13, 2012 | 04:28 AM
  #35
MastaTech's Avatar
Originally Posted by turbohatch96y7
Lol damn master techs if they can't use a scan tool they're just uti graduates
OK, that's offensive. i could sit here and Mind F*** you with knowledge you wish you knew. I didn't go to UTI, I went to PACT Google it.. Lets be adults.
Old Feb 13, 2012 | 04:31 AM
  #36
MastaTech's Avatar
Have you tried swapping out the Coil and Igniter chip? Some times the igniter gets 'green death' from corrosion. so does the inside of the distributer cap.
Old Feb 13, 2012 | 04:33 AM
  #37
MastaTech's Avatar
Sorry, I'll ask my grandmother not to pass away next time. I really love to help people, I'm sorry I will try harder!
Old Feb 13, 2012 | 04:40 AM
  #38
The Grumpiest
Condolences. But we weren't really supposed to know that were we?
Old Feb 13, 2012 | 05:13 AM
  #39
MastaTech's Avatar
Thanks. I guess now i know not to post such a generic thread! <<N00B problems
Old Feb 13, 2012 | 06:54 AM
  #40
turbohatch96y7's Avatar
Okay masta tech you should know this....
Swapping obd1 and 2 distributors does not work. You need to. Swap the rotors inside since they are in at a diffrent degree. That is why your getting no spark.
Originally Posted by Marior82003 I need help with my engine. Doesn't get a spark. I've been searching the threads and I've tried pretty much everything and still no spark. I have a b16a2 with an obd1 ecu and obd1 harness. But here's the kicker. I have an obd2 distributor and a crank sensor down toward the shaft. Here's my question. Does the obd2 distributor need the signal from the crank sensor to give off spark? Cause i was told I didn't need the sensor since it was obd2. Thanks in advance if someone can help.
Old Feb 13, 2012 | 08:02 AM
  #41
HondaPartsHero's Avatar
Technical Hero
Actually that's wrong OBD1 and 2 distributors are interchangeable with OBD1/2 ECUs. OBD1/2 ECUs are not compatible with OBD0 distributor and vice versa.
Old Feb 13, 2012 | 08:34 AM
  #42
Marior82003's Avatar
I've traces the wires and they seem to be where theyre supposed to be but I'll double check. I got new main relay, new distributor, new spark plugs an wires and even tried two known good ecus. I've ran out of ideas and theories.
Old Feb 13, 2012 | 09:18 AM
  #43
GagnarTheUnruly's Avatar
OK here's one:
I've got a 1996 GS-R with a fluctuating idle during warmup. Following throttle inputs, it will idle high and rich (2k rpm) and start fluctuating between 2k and normal idle. Occassionally it will spontaneously die. The hunting idle does not happen if the car warms up with no throttle inputs, although it may still die spontaneously.
The IACV is clean and there are no error codes. I cannot find any vacuum leaks using carb cleaner. The problem does not happen when the car is warm.
Edit: and there are no abnormalities in the ECT readout.
Old Feb 13, 2012 | 09:20 AM
  #44
mouab18c1's Avatar
Grounds are all good. Checked them plenty of times.
Old Feb 13, 2012 | 10:23 AM
  #45
MastaTech's Avatar
Originally Posted by GagnarTheUnruly
OK here's one:
IACV usually wont set a code. they are solenoids and are not monitered. if anthing a generic Idle code will be set. It probably looks clean, but there is still the possibilty of internal binding. sometimes throttle cleaner can clean the grime, if any, but wont solve mechanical binding
Old Feb 13, 2012 | 10:27 AM
  #46
Is there any troubleshooting or should I just try with a new IACV?
One option is I could swap it out with the one on my 99 CRV if they are the same.
Old Feb 13, 2012 | 10:31 AM
  #47
MastaTech's Avatar
Originally Posted by dntnedvtec
Okay. My steering is loose. Not my steering wheel, but steering. Its like I have power steering. It gets worser the faster I go, and every crack in the road, it seems to follow. I have searched and found that there is an adjustment found on the steering rack itself that can "fix" this loose steering. But they don't specify if its for DA or DC, manual or powered racks. I have looked at my rack (DC4) itself, and I do see a bigger "fitting(40mm)" and a smaller fitting(14mm) dead center of it on the rack. Can I adjust it, or should I look else where?
do you have hydraulic P/S or is it manual?
Old Feb 13, 2012 | 10:36 AM
  #48
MastaTech's Avatar
you could try to manually bench test it with a battery and test leads, but that will only show ON or OFF movement, not sweeping. am not sure if they are the exact same, i do know a lot are interchangable. i quick call to Auto Zone could answer that, Honda and Acura dealers hate being dicked around with that stuff, especially if you dont intend to buy that minute. part of the Honda truoble shooting says "Substitute With Known Good IAC Valve and Continue" Also check your coolant level. air bubbles can cause they same issue becuase the IAC is heated directly form the coolant.
Old Feb 13, 2012 | 10:51 AM
  #49
It might have been obd2a\b.
I would take the distributors out place the rotors side by side and double check.
Old Feb 13, 2012 | 12:31 PM
  #50
nealy8849's Avatar
I have a 1998 Honda Accord cf3 japanese 1.8vts. i need a ECU module. part number is 39980-sor-023. new or used, the one i gave is not taking the reset code, connected the jump start cables wrong during a jump start, now it doesnt work.
