do you HAVE to have it?
Old Sep 24, 2004 | 08:02 AM
eg6T's Avatar
Default do you HAVE to have it?
do u absolutely need the coolant reservoir? it gets in the way of my intercooler pipe,i just want to know if it would be a problem to remove it?thanks
Old Sep 24, 2004 | 08:05 AM
tgreaves's Avatar
Default Re: do you HAVE to have it? (eg6T)
Well if you overheat at all usally the boiled over coolant goes into the bottle.. If you seal that then its going to blow a hose or the radiator.. If you really dont want to run a bottle then I would run a coolant line from the radiator down to the ground.. That way excess coolant will still release..
Old Sep 24, 2004 | 08:09 AM
eg6T's Avatar
Default Re: do you HAVE to have it? (tgreaves)
it would be ok just to run an open line down to the ground?nothing could get messed up from that?
oh and i have a fluidyne radiator
thanks
Old Sep 24, 2004 | 08:14 AM
tgreaves's Avatar
Fluidyne radiators are strong but not that strong.. I would just run a line to the ground..
Old Sep 24, 2004 | 08:21 AM
eg6T's Avatar
alright cool thanks alot man
Old Sep 24, 2004 | 09:35 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6T &raquo;</TD></TR><TR><TD CLASS="quote">it would be ok just to run an open line down to the ground?nothing could get messed up from that?</TD></TR></TABLE>No. When warm some coolant moves into the reservoir. When it cools down it's supposed to get sucked back in. If you leave an open line, then each time you turn off the engine it'll suck air in thru that hose. The radiator isn't designed to have an air space in the upper tank.
All you need is ANY kind of bottle with a hose dropped to the bottom. I even saw a picture of someone used a water bottle. If you used a really small bottle, you just have to watch it & check more often.
Old Sep 24, 2004 | 10:00 AM
tgreaves's Avatar
Default Re: do you HAVE to have it? (JimBlake)
This is true but my overflow bottle is always empty and I have never had a problem.. But I do know that it does that..
Old Sep 24, 2004 | 10:57 AM
JimBlake's Avatar
Back in the day... The radiator's upper tank would have been larger to prevent air bubbles from being carried along with the water flowing down thru the radiator core. Bubble entrainment isn't a 2-minute calculation, so I'm not gonna do it now.
But if you haven't had a problem, then I guess it's not as close as I guessed???
Old Sep 24, 2004 | 02:07 PM
eg6T's Avatar
thanks alot for the help guys
Old Sep 24, 2004 | 04:10 PM
91civicDXdude's Avatar
you cannot pass tech inspection with an open hose leaking coolant onto the track.
Old Sep 24, 2004 | 04:58 PM
eyeamvic's Avatar
Just relocate it where it clears.
67mmlsv
Apr 22, 2014 09:32 AM
Hemix
Feb 5, 2010 01:30 PM
96WhiteOnBlack
Apr 5, 2007 08:01 AM
nvmonkeys
May 7, 2004 09:46 AM
King_j
Jul 14, 2003 09:33 AM
