Do I need to install a resistor box?
Old Dec 6, 2011 | 05:17 PM
DillyD's Avatar
Default Do I need to install a resistor box?
I have a 96 honda prelude Si. I did a JDM H22a swap and converted back to OBD1. It is currently running on a stock jdm OBD1 p13 ecu and runs well. I am swapping the ecu to a P28 chipped and I have been told I need to install the resistor box is this true? Not just because the ecu but just in general. Help would be amazing. Thanks in advance
Old Dec 7, 2011 | 09:28 PM
10psiLsEf2's Avatar
Default Re: Do I need to install a resistor box?
Resistor box will only be needed if you are installing different injectors that are PEAK AND HOLD type injectors. Your car has SATURATED injectors.
No you dont need a resistor box to convert to obd-1
DillyD
Dec 6, 2011 09:25 PM
raidacaipo
Feb 15, 2009 01:33 AM
raidacaipo
16
Feb 15, 2009 12:26 AM
uneek4dr
Feb 11, 2003 12:14 PM
