Do i need a bigger impact gun.
Old Dec 30, 2010 | 10:09 AM
b16bri's Avatar
Default Do i need a bigger impact gun.
I'm having trouble getting my Rusty exhaust bolts off. I been useing my craftman impact gun how ever i've tryed heat from my propape torch and i've used a lot of PB blast. and I still cant get the bolts off ive been hammering on them for 2 hours with the impact gun Do i need a bigger one ? It's a 1/2 inch craftsman 230lbs of max torque should I get a bigger one is this the reason why i cant break them loose lets say a 400-600lbs of torque would that work
Old Dec 30, 2010 | 10:13 AM
mouab18c1's Avatar
Default Re: Do i need a bigger impact gun.
The bolts are probably rusted on there.
Old Dec 30, 2010 | 10:55 AM
IN VTEC's Avatar
You need more heat. Try a MAP torch or find an exhaust shop with oxy-a.
Old Dec 30, 2010 | 11:12 AM
fcm's Avatar
fcm
Old Fart
Cut them off like a muffler shop would. 94
Old Dec 30, 2010 | 12:41 PM
b16bri's Avatar
i was thinking of taking a cut off wheel to it and cutting threw the bolts. But would a bigger gun with more torque work or should i not even attempt that route
Old Dec 30, 2010 | 12:43 PM
mouab18c1's Avatar
Cutting it off is cheaper
Old Dec 30, 2010 | 02:26 PM
fcm's Avatar
fcm
Old Fart
A bigger impact will probably sheer the bolt anyway. 94
Old Dec 30, 2010 | 03:23 PM
b16bri's Avatar
cutting it it off with a air grinder, dremmel with cut off wheel which is better ? Also what is a MAP torch as someone recommended
Old Dec 30, 2010 | 03:30 PM
h22 civic's Avatar
IF YA GO WITH A bigger gun get a titanium
Old Dec 30, 2010 | 05:41 PM
ownedevo10's Avatar
If you get a bigger gun your just going to snap the bolt so you might as well save your money and just cut them off with a wheel....
Old Dec 30, 2010 | 06:41 PM
b16bri's Avatar
whats the best tool to cut it off with
Old Dec 31, 2010 | 02:30 PM
sc34dc4's Avatar
Personally it sounds like you don't have a clue at all. I'd use something that cuts if it was me.
Old Dec 31, 2010 | 06:24 PM
the171's Avatar
when it dont come off with the gun I grab the big breaker bar. when that dont work, its time to cut. I often find bolts that are too snug for the impact.
Old Dec 31, 2010 | 07:19 PM
b16bri's Avatar
Cutting the bolts off crossed my mind I was just wondering if a bigger gun would work before going the cutting route. Because i figured 230 foot lbs of max torque wasent a whole lot. I dont however want to snap the bolts. And I didn't mean for it to sound stupid as for what would be better to cut it off with i was just trying to get peoples opinions. I've never cut any exhaust bolts or anybolts on a car for that matter and i have battery grinders air die grinders air angle grinders and a dremmel with a cut off kit that says it wouls go threw metal. So I was just trying to get peoples opinions. Next time i go under there i'll try the gun again the breaker bar and than grinder.
Old Dec 31, 2010 | 08:19 PM
PyroProblem's Avatar
230 ft/lbs of TQ is nothing for a 1/2" impact.
I think my IR titanium is something like 700 ft/lbs...
Old Dec 31, 2010 | 09:34 PM
b16bri's Avatar
PyroProblem Re:.230 ft/lbs of TQ is nothing for a 1/2" impact.
Thats what I figured Especially when talking about really rusty exhaust bolts. So now the questions do I cut it like several peoples said or get a bigger gun like some people said ? I would rather not cut it if not needed.... However I dont want to cause more harm than good and break or snap the bolts...
Old Dec 31, 2010 | 09:55 PM
If there really rusty, then there probably gonna break either way. Do them by hand and they might break.Use an impact gun, they also might break...
You should invest in a good impact though anyways. Good tools are always a good investment...
I would try everything else first before cutting or drilling them out. Cutting/Drilling to me is the last thing I want to do.
If all else fails though, you will probably have to resort to cutting it...
There is this tool called a "screw knocker" or "old man". Its used alot in aviation structures and also automotive. Basically its a punch that goes into an air hammer or rivet gun. You attach a socket at the end of the set, and it will hammer the fastener as you turn it....
Good luck!
Old Jan 1, 2011 | 11:20 AM
http://www.mysears.com/Ingersoll-Ran...ws?tab=reviews
This is what you need or something similar to oit. Check pawn shops in your area. I see impacts similar to these going for ~ $100 used..
blackccoupe
Sep 23, 2010 08:13 PM
CivicSi95
Nov 14, 2009 08:53 AM
beatthisspeed69
May 2, 2007 07:55 AM
civiccoupe94
34
Nov 17, 2005 08:15 AM
Ronin Integra8
Jan 8, 2003 05:57 AM
