Do I have a IM or TB Leak somewhere??
Old Jun 26, 2011 | 03:23 PM
pcguy760's Avatar
Default Do I have a IM or TB Leak somewhere??
Using the DIY boost leak tester as pictured below - I basically hook up the leak tester to my turbo charge pipe, right after the turbo and for some reason the little gauge on the compressor will not go more than 5 psi. I am not sure if there is a leak or if it is because I am using a kinda small 12v tire inflator type compressor (cannot "flow" enough air perhaps?)...
Any suggestions?
Old Jun 28, 2011 | 10:04 AM
pcguy760's Avatar
Default Re: Do I have a IM or TB Leak somewhere??
Used a bigger compressor with 20 psi steady and intake plenum gasket was the culprit also my MBC for some odd reason wow ... Glad I found it before hittin the dyno and having my tuner wonder why the turbo was not making more than a few psi lol.
simjosh
Mar 30, 2016 10:59 PM
boosted03
Apr 2, 2013 05:34 PM
gizmoto2000
Jul 25, 2011 11:11 AM
WrongWD
Aug 4, 2008 08:46 AM
jolt-tsp
Nov 20, 2004 09:13 PM
