DIY Intake Manifold
Old Feb 2, 2003 | 12:25 AM
civicmark's Avatar
Default DIY Intake Manifold
I saw this on homemadeturbo.com and i can weld well enough to make one, but i was wondering what measurements would work best, if anyone knows? It says that he used 'the same specs as the STR/Venom intake manifolds'. Does anyone have these, or know where i can get them?
Old Feb 2, 2003 | 07:11 AM
civicmark's Avatar
Default Re: DIY Intake Manifold (civicmark)
ttt
Old Feb 2, 2003 | 09:19 AM
hs2000's Avatar
why don't you just by one?
Any home made one is not going to be as good as a tested and tuned one.
Old Feb 2, 2003 | 02:16 PM
sslude's Avatar
Default Re: DIY Intake Manifold (hs2000)
i wouldnt recommend doing that. you mihgt lose some power. but i gues if you know what you are dong then go for it. but i would just buy one, its safer and less of a hassle
Old Feb 2, 2003 | 02:37 PM
GZERO's Avatar
if you are planing on making one you have to start reading a lot, intake manifolds play with a lot of formulas cuz you need to determine several things, go and luck on the net and read, i'm sure you can make yours and do whatever you want, just do a lot of research before doing it. i have a good link of the basis, i'll try to look that up.
EDIT: found it http://www.grapeaperacing.com/GrapeA...ntaketerms.cfm
[Modified by GZERO, 6:40 PM 2/2/2003]
Old Feb 2, 2003 | 04:38 PM
civicmark's Avatar
Default Re: DIY Intake Manifold (GZERO)
thanks for a great start, i'll keep everyone updated as the projects moves forward.
Old Feb 2, 2003 | 06:07 PM
GZERO's Avatar
ok, good luck man. just do your math and you will be ok
SR20S13
10
Sep 26, 2010 06:24 PM
ek9jin
Honda Civic (2001 - 2005)
Jul 15, 2009 02:41 PM
vansprinkle
Honda Fit
Apr 24, 2007 07:49 PM
ralpheezy
Mar 14, 2005 05:06 PM
Travis922
Dec 11, 2004 05:17 PM
