GSR swap Fuel issue? Cuts out at lower RPM?
I recently bought a 97 hatch with a GSR swap car ran pretty good when I first drove it. The more I drove it the worse it got. Car bucks and cuts out violently upon acceleration at lower-ish RPM but stays running. And purges on idle. I replaced TPS and MAP sensors along with new wires and plugs hoping to fix the issue which it did not. After about 5 minutes of the car running I pulled the new spark plugs and all of them were completely black.
Re: GSR swap Fuel issue? Cuts out at lower RPM?
What engine management are you using ? You said that you swapped the MAP sensor and there is no change... what throttle body do you have ?
Post a pic of the throttle body please. Also, list the wire colors in each of the TPS and MAP sensor plugs.
TPS is three wires. yellow wire with a blue stripe, green with a black stripe, and red with a black stripe
MAP is three wires. Yellow with a red stripe, red with a green stripe, and green with a white stripe
also if you need me to take the throttle body off for pictures let me know they should be attached let me know if you can see them.
MAP Sensor
TPS Sensor
supracrx
10-29-2006 10:00 PM
