DIY 5 lug ?
Old Nov 9, 2003 | 01:41 AM
mtber's Avatar
Default DIY 5 lug ?
Looking for the DIY 5 lug article...
Old Nov 9, 2003 | 01:42 AM
mtber's Avatar
Make you're own 5 lug using blah & blah for parts & reuse you're trailing arm blah blah..
Old Nov 10, 2003 | 07:08 PM
phantom_sol's Avatar
Default Re: (mtber)
i wonder if you can replace just the spindle, keep your stock brakes and whatnot just to switch the lug pattern to 5 lug. anyone know the spline and the size of the axle nut for this application? and if its cross compatible with civic and integra axles?
Old Jan 4, 2004 | 04:26 PM
jg's Avatar
jg
Default Re: (phantom_sol)
I'm bringing this one back up.
If you ordered new bearings and hubs for a US spec ITR, you could put this in a non-itr steering knuckle and rear trailing arms? Spline and axle nuts are the same right?
Modified by jg at 5:37 PM 1/4/2004
Old Jan 5, 2004 | 09:13 PM
Default Re: (jg)
anyone know if you could use an itr or crv spindle/hub in an integra knuckle?
is there any 5 lug spindle or hub that uses the same spline of a 4 lug integra?
Old Jan 6, 2004 | 03:21 AM
jg's Avatar
jg
We're asking sort of the same question. The itr is the same spline size. I have ITR axles in my '98 'teg GS/GSR steering knuckles. I just don't know if the size/o.d. of the bearing/hub is bigger, or something, that may prevent it from being pressed into the normal 'teg steering knuckles...?
Anyone know this one? OR, does anyone have access to both parts?
Old Jan 6, 2004 | 02:02 PM
jg's Avatar
jg
Default Re: (jg)
anyone?...
vu337
Apr 27, 2009 04:40 PM
denraweb
Nov 29, 2008 07:01 AM
boostedcivicsir
Mar 27, 2007 05:18 PM
thad
Welding / Fabrication
41
Oct 17, 2004 10:06 AM
