distributor help
Old Oct 30, 2009 | 10:19 AM
Supahatch's Avatar
Default distributor help
Hey guys I'm finishing up my z6 swap in my hf with obd1 conversion. I'm not getting any spark getting plenty of fuel tryed diff main relays but still no spark. Then I got my multimeter out and I'm getting 12v to the plug that only has two wires. But when I try to find voltage on the big plug I'm not finding anything over .8v. Is this plug suppose to have 12v? All fuses are good also. Thanks for the help
Old Oct 30, 2009 | 04:34 PM
KWayRacing's Avatar
Default Re: distributor help
Are you throwing any DTCs?
Old Oct 31, 2009 | 08:07 AM
Supahatch's Avatar
No not throwin any codes. Is there a wire on the bigger plug that carries 12v? Or does just the smaller plug carry it to the dizzy?
Old Oct 31, 2009 | 08:36 AM
KWayRacing's Avatar
Do you know that your distributor is good? Did you use a jumper harness at the distributor also?
Old Oct 31, 2009 | 09:08 AM
Supahatch's Avatar
No I bought it on ebay and said from runnin vehicle. But u kno how that goes. I did the ohm test on the coil and it was within spec I cut and soldered on the obd0 plug on the dizzy and tried swaping the two white wires that are commonly wrong still nothin
mahatma
Jun 9, 2006 04:14 AM
Honda_18
Nov 27, 2004 10:07 AM
Quick Silver
Nov 23, 2002 11:39 AM
reese
Jun 10, 2002 11:13 AM
