distributer problems?????
Old Aug 19, 2004 | 04:14 PM
haophat's Avatar
Default distributer problems?????
So i had a dist lock up on me and got a new one put it in new cap and rotor and it still does not work??? do I have to re set the ecu??
its a b18a 90 teg on g2ic to reset the ecu it says "ECU Reset procedure. (Perform every time when troubleshooting)
1. Turn the ignition switch off.
2. Remove the BACK UP fuse (7.5A) from the under-hood fuse box for 10 seconds to reset ECU
i am nit the best tech but there us no fuse labeled "back up" under the hood so i am just confused
any
help please
Old Aug 19, 2004 | 06:26 PM
Jimmy's Avatar
Global Moderator
Ok if you bought a new distributor and it still doesn't work ever thought it may not be your dizzy or you have a bad cap and rotor,etc.
Cripton805
Apr 18, 2010 04:07 PM
tbuck23
Apr 1, 2007 05:50 PM
haophat
Aug 19, 2004 10:59 PM
vinuneuro
Mar 19, 2004 12:13 AM
DSayavan
Jul 21, 2003 06:48 PM
