dist question
I got a d16y7 motor in my crx and its gonna be runnin a a6 ecu. My question is, is the only dist i can use the a6?
Yager-
Yager-
Actually, you should be able to use any 88-91 SOHC distributor on a Y7 head, but I strongly suggest you stick with a distributor that came from a multi-port fuel injected (4 injectors) engine (Si or HF).....as the dual-point engines have a distributor with a square plug and can make things difficult.
[Modified by Katman, 12:46 PM 11/13/2002]
Randysi
49
Oct 30, 2011 09:54 PM
