dist bearing locked up? what to do??
Old Aug 21, 2004 | 12:14 PM
haophat's Avatar
Default dist bearing locked up? what to do??
So my dist, bearing was making noise and I thougth I woudl get to it, but it locked up before I could, I got a new dist, and put it in but now the teg will not start? is there anything else that may have tripped, ie. a blown fuse? or computer malf?
any help would be apprechaited
90 integra b18A manu.
thanks
Old Aug 22, 2004 | 01:38 PM
Cynical 1's Avatar
Default Re: dist bearing locked up? what to do?? (haophat)
Do you have your distributor in correctly? 180 degrees off? Timed properly?
Old Aug 22, 2004 | 03:38 PM
haophat's Avatar
Default Re: dist bearing locked up? what to do?? (Cynical 1)
finally got it back up and running, it was the timing, the locked ist, must have made the cam skip a few teeth on the timing belt, and that threw it all out of sync, and bcause of the TDC sensor it was not firing at all, so dizzy is all good and everything is back and running, I hope this post omes in handy for others who face this problem, it was a real headache!
dannyboief9
Feb 21, 2010 07:23 PM
JasonST
Jun 29, 2009 09:47 PM
Dancing is Forbidden
10
Aug 25, 2005 02:56 PM
acclude435
Dec 3, 2004 03:31 PM
Origin
12
Feb 11, 2004 09:31 AM
