Different types of honing? Explanations please.
Old Dec 31, 2003 | 07:50 PM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Community Influencer
Default Different types of honing? Explanations please.
I've seen on some machining sites what seems to be two different types of honing. One method which just seems to be a normal hone and the other called a line hone (which always costs more). I'm guessing a line hone is when they index off the crank? Could someone explain the various methods and which is the proper way for a well built engine? Thanks in advance.
Old Dec 31, 2003 | 07:57 PM
the DR.'s Avatar
Default Re: Different types of honing? Explanations please. (ActiveAero)
I'm not sure which sites you're looking at, but the 'usual' honing most commonly refers to honing/deglazing the cylinder bores, while a line hone is for the main journals.
Old Dec 31, 2003 | 09:06 PM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Default Re: Different types of honing? Explanations please. (the DR.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by the DR. &raquo;</TD></TR><TR><TD CLASS="quote">I'm not sure which sites you're looking at, but the 'usual' honing most commonly refers to honing/deglazing the cylinder bores, while a line hone is for the main journals.</TD></TR></TABLE>
Well I guess that explains why its always extra . At least I learned something lol. Well I've seen talk of people indexing (might be another term) off the crank for honing, but then I know of people that have just had there bare block sent off to be honed.
Old Jan 5, 2004 | 09:13 PM
samdubs00si's Avatar
You might be thinking of a line bore, where they index off the crank when boring the cylinder, but not honing. Honing is normally done with 3 stones that are spring loaded used to clean glazing off of the cylinder so when you put the new rings in they can seat properly.
Old Jan 5, 2004 | 09:25 PM
onesikviet's Avatar
Default Re: Different types of honing? Explanations please. (samdubs00si)
how much is it for a normal honing job. b16 block
Old Jan 6, 2004 | 09:37 AM
BoOsTeD_eK's Avatar
Default Re: Different types of honing? Explanations please. (onesikviet)
I thought honda oem honda sleeves required some special honing technique? Anyone have any info on that?
techtuner
Sep 24, 2010 07:02 AM
Kaspk
Apr 6, 2007 03:12 PM
Pikachu
Mar 6, 2005 03:29 PM
loudsubz
Jul 16, 2004 10:57 AM
