Difference between coilovers and "true coilovers"
GCs don't have shocks. They aren't coilovers, they're spring sleeves. Only dumb people call them "coilovers".
Tein HAs have a threaded shock body that the spring perch threads to adjust ride height. The GCs have a sleeve that grips the shock body in a very similar manner. IT cannot have threaded shock bodies so GCs and upscale adjustable shocks can be used. I personally have GCs with Koni Yellows. Both the Teins and the Konis require shock re valving when spring rates approach 600 lbs/in.
The advantage of the HAs is that they have an aluminum damper, which weighs less. This can significantly reduce unsprung weight if they are inverted (requires custom work/kit).
I'm pretty sure that answered your question.
Modified by GSpeedR at 6:55 PM 7/7/2003
yep. GCs are just sleeves with springs while REAL coilovers have the shock and springs with perches and such, they are ONE piece. coilover sleeves(GC's, dropzone, APC, maxspeed,) are not true coilovers.
I prefer springs over sleeves anyday
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek9t »</TD></TR><TR><TD CLASS="quote">teins dont have sleeves... the shock itself is threaded for the perches</TD></TR></TABLE>
true. also, true coilovers, the springs are designed to go with the strut.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">true. also, true coilovers, the springs are designed to go with the strut.</TD></TR></TABLE>
Yup, you can see some of the pics I took the other weekend of my suspension swap. Hopefully these clear that up:
http://www.netpath.net/~dkpeters/TEIN
I think they are great! The ride is so much cleaner with the TEIN HA's than it was with aftermarket (Koni Yellows) shocks and adjustable sleeves. The construction is so much more solid as well, with no chance of anything rattling and/or breaking loose.
HTH.
Dan P.
HTH.
Dan P.
tein HA's are great. I ride with them a bit stiff though, i think its 6 up front and 4 in the rear. 16 being stiffest, 1 being softest. I like it, but i dont think my passengers do. haha.
because they are not a tuned set, they are not test with each other(shock and spring) which a true coilover like tein is testing, they are on unit.
not to mention the shock can be fix if the shock is blow
EK4civichatch
16
Oct 1, 2005 07:25 PM
